Drop in IAT by disconnecting hot water feed to the throttle body?
Has anybody done this? I have read about this on MLR, but was not able to find any posts on evom about it except for this one on lancer ralliart forum. The idea is to disconnect the warm water feed to the throttle body to help keep air intake temperatures low.
This was also recommended by a reputable UK tuner. According to him, even in the UK's colder climate they did not have any problems with the trottle body sticking in cold weather
Is there any gains to be had from this? Surely if it worked, people in the USA (especially in hot southern states) would be doing this.
I am surprised that nobody on evom has tried it before... There is some info on MLR. Usually there is tons of info on similar topics on evom - not this time. Kind of strange as USA is much warmer than UK making this mod worth more here
I think I'm going to go try it as well. The summer heat is making my car run **** poor
EDIT: I just realized that I could try and log before and after with our shop's MODIS and see if there is any difference in the IAT as well as other temps.
i have done this on my lancer and took before and after temperature readings. heres the thread...
https://www.evolutionm.net/forums/sh...d.php?t=251402
not sure exactly what its worth, but theres a pretty noticeable difference in temps.
heres another thread on it with results...
https://www.evolutionm.net/forums/sh...d.php?t=265352
I have done it. I didn't see any difference since konck level and all stayed the same but I am sure it will help little. be prepared for rough idle when TB temperature swings between hot and cold.
People in the U.S. have been doing this basic, "free mod" since the mid Nineteen- Eighties. The G.M. guys all used to do this on their EFI Camaros and SFI Turbo Buicks too.
Disconnect both coolant hoses from their throttle body inlet and outlet fittings. Then, finish removing one of the two hoses altogether, by removing it from its fitting on the engine. Finally, take the one remaining hose, which is still connected to one of the two engine coolant fittings and loop it to the other empty fitting on the engine. So, you end up with two empty, unused fittings on the throttle body, and one hose connecting the two fittings on the engine. Sorry, I made it seem so confusing
EDIT: By I.A.T., you are refering to intake air temperature, and not to its more common meaning of, idle air temp, right?
Last edited by sparky; Jun 19, 2007 at 06:10 PM. Reason: futile swipe at clarity by an old geezer
