Hot outside temp and bogging
Old Jun 25, 2003, 09:20 AM
EVO SPECIALIST's Avatar
The ECU is still doing its job.I'm not really tricking it,I'm rapidly cooling the air going through the intake and intercooler,w/o put the motor in danger and w/no use of chemicals
Old Jun 25, 2003, 09:21 AM
mayhem's Avatar
come on! spill it You using the A/C for something or icepacks?
edit: oops, sorry, just read your last two posts on the 1st page.
Old Jun 25, 2003, 09:25 AM
I don't want to give up to much cause I plan to present it to Mitsu.Corp. in Ca. and market it,but if you call I tell ya,MSRP LIST,MI-Fox Mitsubishi.
Old Jun 25, 2003, 09:36 AM
Peazoo's Avatar
I have an idea what he his doing. I have been looking at applying this technology to autos since I am in the manufacturing industry. I will not disclose anything due to his working on marketing the product.
EVOSPECIALIST - did you get yours from Chris at Fox?
Old Jun 25, 2003, 09:43 AM
I am Chris
Old Jun 25, 2003, 11:05 AM
silverEVO8's Avatar
Sounds like an application for a venturi tube type of air cooler?
Old Jun 25, 2003, 12:31 PM
timzcat's Avatar
I have some magic beans that will make your car faster. Any buyers?
I was thinking he is using some type of peltier effect on the IC pipe?
Old Jun 25, 2003, 12:45 PM
amigoni's Avatar
I live in Colorado and it's hot. No matter how much the ECU compensates you still loose a ton of HP out here. I Can only do 0-60 in right under 7 seconds with my EVO here.
Old Jun 25, 2003, 12:55 PM
Im from colo.springs
Old Jun 25, 2003, 01:08 PM
timzcat good guess but no,and they are magic beens
Old Jun 25, 2003, 01:32 PM
Evo D's Avatar
I'm guessing Peltier junctions with enough cooling power to make a difference would require more HP to generate the electricity they'd require than you'd gain with the cooler charge. Magic beans though, NOW you're on to something!
Dan
Old Jun 26, 2003, 04:56 AM
Peazoo's Avatar
Chris, I'm the red acura. Did you take the illinois car? Anyways, PM me... I have some questions about what to look out for in the service dept.
Old Jun 26, 2003, 05:07 AM
Peazoo's Avatar
There is another way to produce cold air without electricity. This is all I will disclose so EVOSPECIALIST keeps his project under wraps
Jdizzo33
Dec 2, 2016 12:23 AM
Walkingchaos
Lancer Engine Tech
Dec 17, 2006 08:57 PM
inphluence
Dec 26, 2004 07:26 PM
Illrunya
40
Jan 15, 2004 10:30 AM
Bleed
May 22, 2003 04:47 PM
Quick Reply: Hot outside temp and bogging
