Hot outside temp and bogging
Old Jun 24, 2003, 04:39 AM
Peazoo's Avatar
Has anyone noticed the bogging since it is getting hotter outside?
Especially in stop/go traffic. I wish there were a remedy instead of having to work the clutch so much to take of in fear of stalling the engine.
Old Jun 24, 2003, 11:50 AM
silverEVO8's Avatar
Re: Hot outside temp and bogging
Absolutely, the car is positively slooooow compared with what it was in March .... All kdding aside, the hot summer temps are very hard on FI cars, the EVO seems to suffer even more than did my WRX
Old Jun 24, 2003, 12:07 PM
diesel_fan's Avatar
Hot, low density air is hard for anything (car, boat, plane) with nearly any type of engine. If it's a typical 95deg day with high humidity and you're at sea level (or close), the actual performance (or density altitude) might be around 7000ft. So imagine being higher up than Denver, you're going to notice lower performance. The turbo would have to spin even faster to generate the same boost pressure as on a lower temperature day so it takes somewhat of a efficiency hit as well.
Eventually in the hottest parts of the summer places such as Phoenix / Sky Harbor Airport get so hot that many types of jet aircraft can't take off during the day since they are so performance limited due to the ridiculous density altitude.
Old Jun 25, 2003, 03:00 AM
Peazoo's Avatar
I understand it affects all cars. Doesn't give me much confidence to drive it hard though.
Old Jun 25, 2003, 05:56 AM
silverEVO8's Avatar
Actually, the car is probably safer at the hotter temps because the mixture will run richer (the air density is lower for a given amount of boost). I think the most dangerous times for detonation are those very cold, low humidity days, when the car makes lots of boost with high density air and the mixture is too lean... Please correct me if I'm wrong.
Old Jun 25, 2003, 06:20 AM
EVO SPECIALIST's Avatar
I am working on a Idea to fix that problem,permantly!!so no matter summer or winter,you will maintain the same power out put?But I am now in test stages
mayhem's Avatar
that makes sense but wouldn't the MAF eventually make it lean out some with the low desnity air?
Old Jun 25, 2003, 06:25 AM
Oh my car will be the Victo.....I mean the test car I will let you all know today!!!
Old Jun 25, 2003, 06:43 AM
Peazoo's Avatar
I believe the ECU compensates anyways for the air density. I was talking about lack of performance because of the temp. I don't wish to punch it vs a vette when its so hot outside.
Old Jun 25, 2003, 07:15 AM
silverEVO8's Avatar
I believe the MAF measures air flow. It does not know how dense the air is. That is why it's so important to watch the EGTs and A/F ratios when the temps drop. The hot air has less O2 than cold air relative to volume, therefore the fuel adjustment based on the air mass would be richer for hot air than for the same mass of cold air.... Or at least that is what it seems to me.
Old Jun 25, 2003, 07:25 AM
Thats what I am working on,I think I have made it work,95degree here and I am back at 19.3PSI with no bog down or lag
Old Jun 25, 2003, 08:25 AM
Peazoo's Avatar
What did you do? Will this not create a problem when the outside temps drop to nominal. Please share your secret!!!
Old Jun 25, 2003, 09:06 AM
mayhem's Avatar
the MAF measures air flow yes, but in a way it measures the density of the air as well. unless the MAF is different than others there should be a heating element in the MAF and it measures how quickly the air flow can cool it down. Flow of desne air will cool it faster than an identical flow rate of less dense air. I don't know what the ECU will do when it senses less dense air, lean fuel or mess with timing... probably both.
just checked manual. "When the engine is cold or operated at high altitudes, the ignition timing is slightly advanced to provide optimum performance." High altitude or low density air is the same thing. So we know at least the timing is advanced.
There's pretty good description of the MFI system starting on 13A-671 of the tech manual. Should help give an idea of the relationship between O2 sensors, Emissions system, Intake air tem sensor, Engine coolant temp sensors, CAS... hopefully someone that knows the ECU well can chime in with real world applications rather than me just quoting from a manual. Vendors maybe?...
Peazoo, the Evo already has low power in the lower rpm range. With increased air temps that power is weakened even more. this causing more bogging.
Are you somehow tricking the EcU to think it's a different temp or something..?? I'm real curious to know what it is your doing and how. I can't imagine a better system for dealing with high temps then what the ECU does..do tell.
Old Jun 25, 2003, 09:14 AM
I will let you know soon,but it will be something you can turn off in cooler weather and the watersprayer will last 2x as long
Old Jun 25, 2003, 09:16 AM
Mayhem the answer to your ? is yes! or Im cheating the elements,but I promice you will hear about it,I have been working on this for 2 mon. now
Quick Reply: Hot outside temp and bogging
