Southbend OFE Clutch Install Pics
Last weekend I removed the restrictor pill from the slave cyl on my 05 Evo VIII. It was a great mod and I'd almost recommend it to anyone with the stock clutch. I say almost because it improved the clutch engagement so much that I decided to practice my launches for an upcoming drag event. After 5 launches, my technique was improved upon, but my stock clutch was not happy. Driving to work became a tedious task of delicately touching the gas pedal and shifting as early as possible in each gear. My car is mildly modified, still running stock turbo, stock injectors. It puts down about 310whp/290wtq on an uncorrected Dyno Dynamics dyno. I drive the car to work daily and consistently clock 40-50 miles each trip, sometimes much much more. Anyways, that's the long way of saying that I'm nice to the stock clutch and it lasted *exactly* 38,998 miles.
My previous car was a very well modified 97 GSX with a similar power level, and it had a Southbend DXD clutch put in it just after I bought it. I loved that clutch, and I knew since I bought my Evo that I'd be putting one in it as well. I have to say, I LOVE this one. Pedal feel is honestly stock feeling, but it is obviously more grabby. It seems as though most evo guys run ACT or Exedy clutches, and that a lot of guys jump for the twin-disc setup for no really good (IMHO) reason. A single disk is less complicated and less prone to failure at these (and much higher, to a certain extent) power levels. I searched and searched on EvoM for other people running this Southbend OFE (or even their FE) clutch but came up with zero results. I liked my old one so much that this did not bother me at all. Instead, I hope I'm opening up a door for some other people to try these things out.
I was going to be a man about it (read: *save some money*
) but when LSE Performance said they could turn it around in *a day* I basically caved. When they fit me in on a Thursday, three days after the Monday I was talking to them about ordering it(four days after I wrecked it launching), I was sold. Granted, I pushed them a little to up the date but damn it, they DELIVERED!
When I dropped the car off on Wednesday at 3:30 in the afternoon, the clutch had already arrived and I was able to check it over and snap a few pics of this fine piece of metal that I would (hopefully) not be seeing for a long time, but be indirectly touching on a daily basis. The quality is high, and the finish is excellent. I would gladly put it in my car!
I'm not trying to 'just be different' or anything, I just know that Southbend makes good clutches and I want one in my car. If anyone wants to try it out for themselves, I highly recommend placing your order. I got mine from LSE Performance, and I'm pimping their name here one sole basis of a job extraordinarily well done. Josh, Aaron, Swifty, and especially Chris: THANK YOU!!!
Now on to the motherf*cking pics!!!!
![](http://www.scheides.com/albums/evo-southbend/DSC00927.sized.jpg)
![](http://www.scheides.com/albums/evo-southbend/DSC00928.sized.jpg)
LEMME CHEX MAH MAILZ, den I be rippin dis ***** apart!
![](http://www.scheides.com/albums/evo-southbend/IMG_2044.sized.jpg)
![](http://www.scheides.com/albums/evo-southbend/IMG_2045.sized.jpg)
For the record: while I got out of doing the clutch on my Evo, thinking it'd save me all this time, I ended up staying up all night helping my neighbor mount and plumb a new on-demand water heater. GAHH!!!
Also for the record: I have zero affiliation with Southbend Clutch as well as LSE Performance. I just know they make good clutches and do good work. I don't have time for **** to be half-assed, cuz that's how I roll!
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Thanks for the shout-out Chris, glad you were happy.
I forgot you were taking pics back there, the shop is filthy!
We've had tremendous success with southbend, but yes the Feramic can sometimes weld itself to the flywheel.
What most people neglect to inform the customer (or forget period) is that the feramic material absorbs heat and transfer it. It is not a clutch you want to slip or ride. But for the price to holding power ratio, they are top notch. Its no twin disc, but the pedal pressure and easy engagement are really nice.
PolloVagabundo
Mar 24, 2017 10:04 AM
scheides
14
Jun 28, 2008 10:24 AM
scheides
16
Jun 29, 2007 11:19 AM
