20Lt Green vs. GT3071..
Old Jun 28, 2007, 07:39 PM
reeferman's Avatar
Which is the all around best performer? Cannot decide between the two. Drag racing, road racing, street? Videos would be nice.
Old Jun 29, 2007, 08:20 AM
sparky's Avatar
For street use, on pump gas, I´d say the 20G-LT, a.k.a., the EvoGreen, would be clearly superior to the 3071. The Green can be had for a total price which makes the 3071 comparatively speaking a loser´s proposition. I don´t know anything about Drag Racing or closed-circuit, though. So I´ll just keep my trap shut.
The compressor side of the two turbos, move almost identical air at about 48-49 lbs./min. So it goes to reason that peak power is gonna be fairly close. Although, and just maybe, the 3071 would exhibit a slight power advantage at the highest boost levels on race gas. On pump gas however, the Green is the clear winner. The 30 requires high octane fuel to really get into its sweet spot.
In a way the 20G-LT is an overachiever as it outspools the 3071 on journal bearings. The 3071 on the other hand, is laggier inspite of spinning on a ball bearings. Furthermore, if you should go with the 3071, then you´ll need a complete turbo kit, whereas the 20G-LT is a direct bolt-on.
Ultimately, the 20G-LT gives faster spool up, similar peak power potential at a considerably lower overall price. So for the street at least, the 20G-LT is clearly more turbo for the money.
Old Jun 29, 2007, 09:05 AM
s2kguy's Avatar
The 20g is hard to beat for the money and easy of installation.
Old Jun 29, 2007, 09:32 AM
BostonEvo's Avatar
What are the avrage times run ona 20g/lt On pump gas in the 1/4 , Im sure i can find it on here somewhere. But might as well post the comparison =)
Old Jun 29, 2007, 09:49 AM
sparky's Avatar
You´ll find it by searching on the Drag Racing sub-forum. However, I´d be willing to bet you my allowance and a week´s worth of lunch money, that given the same setup and driver using straight pump gas, the Green turbo will beat an identically equipped 3071 car in the 1/4.
Old Jun 29, 2007, 09:56 AM
bboypuertoroc's Avatar
Average would be LOW 11's... but it has broken into the 10's.
Old Jun 29, 2007, 11:24 AM
SIGSP2340's Avatar
Between those two turbos. I would prolly go with the 20gLt. It has been proved well into the mid to upper 400Whp range on Buschurs dyno and Its a great,easy bolt on.
Old Jun 29, 2007, 12:43 PM
Mellon Racing's Avatar
my 20g should be in soon soon, I can't wait to see what kind of power I can get out of it on pump gas since that's what I'll be running 99.9% of the time. I've seem some figures placing it from 350-400awhp with various supporting mods.
I have the 20G, ported/coated stock mani on the way and will be ordering the FMIC.
Old Jun 29, 2007, 07:23 PM
reeferman's Avatar
My understanding was that you really had to turn up the boost on the 20LT to make high hp numbers(25-30psi). That would put it well into the race gas range. On pump gas I thought the 20Lt only produced about 20hp over the IX turbo. The 3071 is capable of close to 400hp pump gas with 20-21psi. Please correct me if I'm wrong. I would be running pump gas just about all the time with maybe just a splash of race gas for added protection.
Old Jun 29, 2007, 07:48 PM
94AWDcoupe's Avatar
the two turbos spool nearly the same. at 21psi the 20g typically makes 360-370 whp. the 3071 makes 400whp at 21psi. you wont find a post of anyone maxing out a 3071 at max boost 35+psi falling to 27 at redline. the 3071 is a turbo that no one chooses. for the money the 20gLT makes much more sense. also when someone considers the 3071 they usually choose the 3076 for more power potential. I did alot of surfing on this turbo looking for numbers. The highest numbers I found were 440-460 dynojet. But the setups didn't sound maxed out.
Old Jun 29, 2007, 07:57 PM
Erik@MIL.SPEC's Avatar
The 3071 spooling the same as an EvoGreen doesn't sound right to me, but I am by no means an expert. I could certainly be wrong, but I just don't remember 3071 owners reporting stock-like spool.
Old Jun 30, 2007, 07:34 AM
mrdevo's Avatar
I think the old br440 kit had the 3071. They made 380-400 on pump and made closer to 450 with some boost. I don't think either setup was pushing it to the max though.
Old Jun 30, 2007, 08:11 AM
I have seen Greens make 380 on 91 and 400 on 93
Old Jun 30, 2007, 08:33 AM
94AWDcoupe's Avatar
and there is a guy on here that made 440 on 93 octane with the 3071 at 25psi. I was quoting average numbers not the highest. buschur had a car that made 360whp on his low reading dyno on pump. shiv had a car do 370 on his low reading dyno as well. both on the 3071. there are lots of ways to run the 3071 as far as hotside goes so spool reports are gonna vary.
Old Jun 30, 2007, 08:36 AM
The 370 on Shiv's dyno, was that on pump?
440 on straight 93 is pretty good.
Quick Reply: 20Lt Green vs. GT3071..
