what is the best oil weight for evo please help!!!
I run Mobil-1 5w30 (their blue cap, "new car formula").
No way I'm giving up a few horspower with a heavier weight oil, with my configuration. With a turboswap, very high horsepower configuration, maybe. But on stock turbo under 350HP i'll be sticking with Mobil-1 5w30...
no hp loss will be had with 10-30w or 15-50w (which is what I run). If you consider that the ONLY time that 5w weight is being used is when you first start it up and run for about 3-5 minutes. After that , all the weights flow like water. My oil (mobil 15-50w) becomes as fluid as anything when it reaches normal temp, which in our cars is extremely high. I would definetely recommend 15-50w MObil 1. As far as start up flow, when you compare standard 5-30w, they both have the same viscosity when cold. Thats the benefit of synthetics. So hp loss is just a theory at best.
The only time you should use 5W-xx is when the ambient temperature is constantly below freezing, otherwise you're just wearing out your engine with such a thin oil.
There is a pretty big difference between a W-30 and a W-50 oil's viscosity at high temperatures. Thats what that part of the oil designation stands for, viscosity at high temperature. So making a statement like "becomes as fluid as anything when it reaches normal temp" is misleading and uninformed. It is thicker at high temperature. It will not flow into very tight machined tolerances as well as a lighter weight oil. If drag induced horsepower loss is actually a factor, it will be worse with the thicker oil as the crank splashes into it.
I am sticking with 10W-30 oil myself, in accordance with the warranty guide. Brand is not as important, so long as its high quality and meets the requirements stated by Mitsu.
WelDun1 (Jul 22, 2020)
If a xW-40 could be found it would be perfect. The motor in the INfiniti Q45 has some of the tightest bearing clearances of any motor and the manufacturer recommends xW-30 although xW-40 and xW-50 is perferred by performance enthusiasts. The only thing that might suffer is a fraction of a MPG. Other than that you're only perserving your engine.
Lets say If you have 10W30 oil the 10W stands for 10 weight winter meaning the oil will remain at a 10<> weight during cold climate for increased flow ,if the oil doesn't reach a high temp it stays light until normal operation temp.after the temp is reached its behavior is of 30 weight. In states like Arizona where temps can be 110°+ all summer 10w30 will probably be just 30 weight. The multi viscosity oils were made to prolong starter and closes tolerance engine life during cold start because the oil from the 50' to 80's was mostly single weight and used in cars that tolerances were measured in much looser clearance. It is recommended if you autoX your car you go to 10w40 to 15w50 but mpg will suffer on daily drivers.higher oil weight =higher oil press lower flow, light oil =lower oil pressure higher flow
2. That is not how oil viscosity works.
colo_evo (Dec 21, 2020)
