fitting forged rods with standard pistons?
there is a very reputable tuner here in the UK who is offering a great price on fitting new eagle steel rods with the engine in chassis and machining the stock pistons to match the new rods.
from there advice they say its not worth doing the pistons unless i plan on running 500-550whp plus, my plan was to stick a 3065 on or possibly a 35r with this setup.
whats everyones thoughts on doing this?
seems like a good route since i cant justify having the whole engine pulled out and rebuild for my power goals, its mainly a road/fun weekend car
Do u mean Simon Norris?
It does work but i would only do it if you were using something like an evogreen or Gt3071,Gt3076.If i was putting on a GT35 then i would put forged pistons in aswell.
yes its simon norris, well my plan is to stick on my fpgreen iv got sitting here for a while but with the potential of running maybe 3065 later on in time, simon says its good enough setup for the turbo's i take his word for it 100% he knows what he is doing however i was just wanting to see if anyone else is running the same setup and how they find it?
anyone?
anyone?
There is a guy john39 or something like that running 530 bhp and he is using a ams stroker kit with eagle rods there is also another guy running the same stroker kit with a gt35r. It all depends mate eagles should be fine for the power your going for.
But if your worried for an extra few quid just throw a set of manley I beams in.
Ive blown the top of the stock pistons apart. They have held together at 500whp and about 200 passes at the drag strip but i had some knock and the top of piston #2 blew apart taking out the turbo also. I would get the forge pistons and be done with it they take allot more abuse and in my opinion cheap insurance the stock pistons aren't as forgiving
true true, just dont wanna have to take the block out, and if done in situe, there could be leakdown issues due to bore clearences etc, heard to many horror strories
end of the day no 3rd party built engine will be as good as oem build quality thats my problem, yes parts used will be stronger but there only as strong as how well they'v been put togeather, which rest assures isnt going to be as well as oem factory machines produce period. unless offcourse you can afford a brand new cosworth block which im sure is built to manufacturars tolernace levels if not better
what was the milleage on your block? in some instances you can getaway with a quick hone just to de glaze the walls a little and fit stock size pistons 85mm. some will require a re bore tho and .5mm larger pistons
