cam decision
Thats a broad question....considering the die hards will insist you do a search, I will ask you a couple of questions...
What are your goals?
Budget?
Ideals (i.e., is a rough idle OK with you as long as you make as much power as possible, or you want the best all around setup?)
You need to determine what you are shooting for and what you are willing to live with to attain your goals, and also what supporting mods you have on the vehicle.
If its a bone stock car, you need to start somewhere else. Its obviously not stock if you're asking about cams, so I'll assume you're ready for it.
For highly modified cars, JUN cams seem to be the choice.
HKS are the staple units as they were some of the first used, but GSC has identical profiles for the HKS units IIRC.
Tomei's ProCams I havent seen used much....they have higher lift than some but there arent enough results that I can find, honestly.
Considering cost and effectiveness, determined by what you're looking for, GSC cams are dollar for dollar the best.
Budget?
well its a daily driver, so i want it to have a nice idle. but at the same time i want the most power and hp. i have to decide between either comp of hks cams.
comp 280's are worth about 10-15 whp over the HKS as per turbotrix. a good tuner can tune out the idle for you. i did a lot of research.
https://www.evolutionm.net/forums/sh...d.php?t=258994
https://www.evolutionm.net/forums/sh...=comp+cams+280
https://www.evolutionm.net/forums/sh...d.php?t=253178
idle-http://media.putfile.com/280280-Comp-Cams-w-Fidanza-gears-set-at-20-idling-at-1200rpms-before-tune
so what cams should i go with the hks 264 or the comp 272/272 cams for my 03 evo 8???? and what should i go with....264,272, or 280(doubt)
my following mods im running now are..
-20g turbo
-ams fmic
-injen uic piping with intake
-mr exhaust mani
-walbro fuel pump
-full tbe
-greddy profec bc
please let me know
thanks
-20g turbo
-ams fmic
-mr exhaust mani
-walbro fuel pump
-full tbe
-greddy profec bc
please let me know
thanks
i have to chose between the comps and hks, i am getting them for an amazing deal!!! the gsc are way to expensive. i just want to know what ones will give me more power and be a better buy....
just read my last post
