Cams... Hks-comp-helix
what cams will make more power on my 03 evo 8. the hks 262/272, comp 272/272, and the HELIX V2 272 CAMS SHAFTS and cam gears come in the package.
i have to chose between these 3 so please help me out thanks
GSC S1. I know they're not in your list, but they should be. I have no idea why you'd list HKS, Comp, and Helix...Helix???? HKS cams work and are proven, but they are about $100 more than Comp and GSC cams without making more power. You also have little-to-need for cam gears unless YOU actually know how to use them. They are for moving the powerband around but don't do anything at all if you just install them.
+1 Thats why i got HKS!
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Just installed my Helix cams. Did not have a problem with my cam sensor bolt or anything else. I thoroughly inspected the cams and they look very well made. Could have been that maybe it was installer error, because you can easily strip the threads on the cam ends.
