buschur cast manifold vs. tubular manifold eg. full race, ams...
Old Jul 8, 2007, 07:59 AM
SlowCar's Avatar
any inputs appreciated!
Old Jul 8, 2007, 08:01 AM
smokedmustang's Avatar
Cast is stronger? Last longer?
Old Jul 8, 2007, 08:05 AM
colo_evo's Avatar
there is a huge thread on this.
buschur tested a bunch of manifolds...
1. full race
2. buschur ported stock
Old Jul 8, 2007, 08:21 AM
EvoM Moderator
scheides's Avatar
Geez man, you of all people! Be more specific, are we talking big turbo manifold or stock?
I'm going to go out on a limb and assume you mean for a big turbo setup, and IMHO it all comes down to what the car is used for. If it's an all-out drag machine, a tubular manifold is the way to go. If you DD or even road race the car, the buschur cast mani is the best option IMHO. Its almost stock looking under the hood, and will be reliable for years to come. Also, the turbine housing supplied with the buschur kit is a nice mix of streetability vs. power for whatever turbo you choose.
Old Jul 8, 2007, 08:22 AM
SlowCar's Avatar
these are all top quality manifolds, not too worried about the durability
i like the stealth like mani of buschur...but how does it flow compared to the tube manis?
this kit i'm looking at:
https://secure.buschurracing.com/cat...9f29f352a6f07c
Old Jul 8, 2007, 08:36 AM
EvoM Moderator
scheides's Avatar
Flow will be very similar; its the same manifold on DB's 9 sec DD (but he's using the HTA 35R)
Old Jul 8, 2007, 08:44 AM
robertrinaustin's Avatar
Location: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Buschur did the test and IIRC, picked up 30 whp by switching from his cast mani with the Mitsu flange to a T3 flanged tubular. However, I really like the "stock" appearance of the cast mani.
Old Jul 8, 2007, 09:10 AM
Fomer Vendor
Kerr's Avatar
https://www.evolutionm.net/forums/sh...22full-race%22
Old Jul 8, 2007, 04:11 PM
richysevo8's Avatar
I think on DB cast manifold the spool up will be quicker,but for out right power the other ones will give more power
Old Jul 9, 2007, 01:20 PM
feldguy's Avatar
Hey smoked. Long time no see!!! How ya been?
Otherwise, cast manifolds were tested by Dave Buschur. he has a reproduced (i think) ported and polished stock style manifold that he uses on a lot of the cars he builds IIRC.
He also has tube manifolds but stands by the cast manifold.
He tested a few tube manifolds with the identical setup from test to test, and the only one to make equal or MORE power was the Full Race stock turbo replacement manifold...
The benefit of a cast manifold=if you drive you car daily and need something to last, cast iron will last almost forever without any issues. Tube manifolds, no matter how well they are built, just cant seem to withstand the high pressure and high heat, which put together, break down the metal in the tube manifolds. The cast manifolds just seem to resist this better...I don't know my metallurgy well enough to explain why, I just know that it does.
There is actually a manifold I am looking for from this thread.
https://www.evolutionm.net/forums/at...5&d=1183596962
It looks like the mitsu WRC, so I doubt I will be able to find it, but there IS a company that a guy from NZ was using for a project that either makes this manifold or something really close to it.
Old Jul 9, 2007, 02:32 PM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
The HAFE cast manifold looks sorta kinda like that
Old Jul 9, 2007, 04:20 PM
VRSF Tiago's Avatar
So buchur makes a cast manifold that fits the stock turbo?
Old Jul 9, 2007, 04:26 PM
kreionic's Avatar
No they port and coat the stocker and send it back to you
Old Jul 9, 2007, 05:21 PM
EVOLex's Avatar
I'd always go with cast, unless the application demands a top mount or a custom configuration.
Old Jul 9, 2007, 08:20 PM
trinydex's Avatar
there are other cast manifolds on the market
Quick Reply: buschur cast manifold vs. tubular manifold eg. full race, ams...
