Aquamist Large Pump Meth Kit - review and tuning notes
#61
good review Al. I knew this kit was off the hook as soon as I unopened the box. I would say it makes other kits obsolete. Thats how much better by design this kit is. its just one of those things where you have to bite the bullet and pay the extra to get the best. in this case its worth every penny the extra cost.
#62
If you want the best - aquamist is the only decision
#63
[I just added the lower boost dyno sharts showing that you onlylosse a few whp with loer more rational street boost levels of 25 psi - car was running great after a few days on the road
AlQUOTE=DynoFlash;4525857]Big props top Richard L from Aquamist for giving me world class tech support and help with the install and confiuration of the Aquamist large sureflow pump meth injection system
The amazing thing about this system is how much superior it is to a progressive boost based injection system
This kit uses injector duty cycle to refrence as load for the alchy injection so you get a totally linear smooth furl map and its very easy to tune
Bascially this is the best kit I have seen or worked with to date - I give it ten thumbs up
Low level indicator and adjustable fail safes complete the package - I loved thing this amazing unit
Bear in mind its a $900 product and it will take at least 4 - 5 hours to properly install
The car in question here is a Evo IX with a 20g turbo and cams regular Buschur Stage III mods etc
The stock Evo IX bov was leaking over 26 psi so we crashed it slightly and the boost came up a bit - this was as far as we could go until the customer gets the Forge RS adjustable bov
I love the aqua mist
I just wanted to add some new data - the customer came back for some test pulls with 5 psi less peak boost and you can see that alothough the tq is significantly lower the whp is almost the same and thios is with 5 psi less
The car was running real good on its return to the dyno for a check up
[/QUOTE]
[/QUOTE]
#65
You can run the lines how ever you like. Either under the car along side the factory brakes lines or in the car under the door sills, or any other way you want.
The pump is wired to the battery for its main power source, but is also wired to the junction box (the brains of the kit) which turns the pump on and off amongst other things.
#66
I assume the plastic line is pretty strong, but I have seen shops tell people that under the car is a wrong install. The SMC lines are braided and run under the car any thoughts on the effect of under the car on the Aquamist lines? I would assume that if you ran them under the car with the brake lines that the brake lines would break first. IMHO!!
Thoughts?
Thoughts?
#68
You can run the hose outside the car and I would think it would be ok. I personally ran mine inside the car under the door sill. If you want you can run it outside and you can run the plastic line inside rubber fuel line for added protection.
DynoFlash
Mar 24, 2009 05:35 PM
DynoFlash
136
Oct 12, 2008 02:47 PM
DynoFlash
41
Apr 25, 2008 07:32 AM
DynoFlash
171
Sep 1, 2007 03:16 AM
DynoFlash
Nov 26, 2006 09:38 AM
