5th gear grind - advice needed
I started getting the infamous fifth gear grind a few months ago (grinding while shifting from 4th to 5th during hard acceleration). I have a mild amount of grind in 3rd gear, as well. I read quite a bit about this on the forum and a number of other people have had the same problem. The consensus seems to be that the synchros are in need of replacement. I called the dealer here in Fresno yesterday and the service manager said that the TSB related to this problem was issued for 03 and 04 Evos (mine is an 05). He also said that some of the 06's have had issues. He went on to clarify that aftermarket clutches were deemed to be the problem in most instances and that such a thing would likely work against the owner in terms of making his/her case. My car has a little over 60,000 miles on it and is still on the original clutch. He seemed impressed and told me that this fact would work in my favor, but that they would need to have a tech drive it and possibly do a tear-down. They would charge me $950 to perform the teardown in order to determine whether the synchros (or anything else) are defective. It would then likely be covered under warranty if that were the case. Here are my options:
1) Pay $50 to have a Mitsubishi tech drive my car and duplicate the grinding (not hard to do - it's pretty evident), pay an additional $950 for a teardown to daignose the problem, and then go from there. If it is covered, I would have to pay nothing at all. If it's not covered, then I'm out a grand just to be told that I need to pay even more money to continue with the repair.
2) Have a transmission shop pull the tranny (10-hour job total at about $85/hour) and send it to Shep for a rebuild (~$1000 with shipping), and then get it back to be reinstalled. I would have a problem trusting anyone else to repair the transmission, since it is a rather complicated and specialized piece of equipment.
3) Drive the car until it breaks and then rebuild the transmission at that point.
My car is stock except for a custom tune from Dynoflash (would detect that or even look for it while pulling the transmission?)
Any thoughts/advice would be appreciated.
1 Post
My friend did about 3 min of some solid burnouts and his tranny whined like a pack of wolves!! He went to mistu within the next 2 days (bald tires and all) And they warrantied the transfer case and 2 of his gears and a couple synchros! Then a month later he rolled it.. but they covered his car with almost 40k!!!
