EVO 8 Alignment
Registered User
EVO 8 Alignment
I had my alignment done when I had the tires rotated and now it drives terribly. It vibrates above 60MPH and I get shaking in the steering wheel under hard braking if going more than 60 when I hit the brakes... I suppose that could be a wheel out of balance as well…
I did not realize at first that they used the alignment settings from a standard 2002 lancer with the 15" wheel option and not for an EVO... I called and asked them and they do not have the EVO's setting in their system...
They setup my car with the following:
FRONT:
Left front Camber: -0.7
Right front Camber: -0.6
Right front Caster: 3.4
Left front Caster: 3.6
Right front SAI: 11.3
Left front SAI: 12.7
Left front included angle: 10.0
Right front included angle: 10.7
Cross Camber: -0.1
Cross Caster: 0.2
Total Toe: 0.08
REAR:
Left rear Camber: - 1.1
Right rear Camber: -1.2
Left front toe: 0.04
Right front toe: 0.04
Left rear toe: 0.11
Right rear toe: 0.10
Rear Total toe: 0.22
Thrust angle: 0.00
Does anyone have the factory alignment ranges? I searched the site and found some suggested settings for camber and toe, but no suggested factory ranges that I could offer to this shop...
I saw these setting as the preferred values:
Front Camber: -1.5 (if possible to get this much stock)
Rear Camber: -0.5
Front and rear Toe: 0
I would like to go back to the shop and give them the correct ranges and have them fix it... Any comments on how they set my car up and where I should have them put it? Is it that bad? I have to say it feels like SH*T…
Thanks,
Chris
FRONT:
Cross Camber: -0.1
Cross Caster: 0.2
Total Toe: 0.08
REAR:
Left rear toe: 0.11
Thrust angle: 0.00
Rear Camber: -0.5
Thanks,
Chris
Re: EVO 8 Alignment
Rear Camber: -0.5
[/B]
Rear Camber: -0.5
[/B]
This is the factory specs, if you search in the Suspension/Brakes/Wheels forum you will find more info on alignment
Front:
Toe-in mm (in.): 0 +/- 2 ( 0 +/- 0.08)
Camber (Selectable from 2 options): -1deg +/- 30' or -2deg +/- 30' (left/right deviation within 30')
Caster: 3deg55' +/- 30' (left/right devitation within 30')
Rear:
Toe-in mm (in.): 3 +/- 2 (0.12 +/- 0.07)
Camber: -1deg +/- 30' (difference between right and left within 30')
Front:
Rear:
Re: EVO 8 Alignment
(snip)
(snip)
I recently changed the alignment to:
F: -1.7 camber, 0 toe
R: factory settings
This is an increase of about 1 degree negative camber in the front, and I couldn't feel a difference on the street. If anything, the steering response dulled slightly, I figure due to less of the sidewall contacting the road, but I dunno.
Yep, i agree with evonick. Sounds like a wheel/tire balance issue, u could take it back to where u got it aligned at and see if they would balance the tires for ya. Maybe the tech knocked off a weight when he rotated your tires. If they won't do it for free, it shouldn't cost much (~20bux).
TxFAkuma
Feb 17, 2017 03:45 PM
idriveanevo
11
Jun 16, 2009 09:45 AM
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
AhmadHasib
14
Apr 12, 2007 07:19 PM
