I have a gt35r kit on my car untuned is it ok to run wot under wastegate pressure?
I have a gt35r kit on my car is it ok to run the car at wot with the boost controller turned all the way down and running by wastgate pressure?
Hey man just spend the money now to get it tuned because motor work will cost you $5000-$8000. So get her A.S.A.P. and I wouldn't drive you car because you are going to ended racing someone.
Huh? so your telling me that the amount of air coming out of the stock turbo at 20 psi is the exact same as the amount of air coming out of a 35R at 20 psi? I don't think that makes sense, or am I confused?
http://auto.howstuffworks.com/turbo1.htm
yes 20 psi is 20psi but the volume of air from the 35r will be much greater
