Forge UNOS Help!
I would invest in 4mm silicone tubing from boostcontroller.com - it will hold up better long term than cheap rubber line from auto parts store. Plus it fits very snug and then just use zip ties for some added clamping.
thats my .02 cents
thats my .02 cents
Try to find some good caps if you're capping on something vital like the turbo outlet or manifold, etc. If you're just capping the BCS, then you can use any kind of cap. The caps crack and deteriorate over time. I've had to replace mine quite a few times already. Real annoying. Definately buy extra vac hose just in case. And get the proper size diameter.
The rubber caps suck......i prefer a piece of line with a bolt shoved in one end and zip tie it. i have been doing it for years and never had an issue
4mm is the diameter you want so everything fits snug, which is roughly 5/32".
roidz3
Nov 3, 2015 08:15 AM
