Need advice on adjusting the Forge Wastegate
Yesterday I installed the Forge Evo 9 wastegate with the piston design. Now I need to tighten the turnbuckle more because even with my boost table at zero, the boost goes up to 24 to 25 psi, Whats the a good techinique to pull actuator arm on the flapper??
Hold on. You left out a lot of information. Are you saying you upgraded to the Forge Evo IX WGA, but you don't have a boost controller? You are trying to use EcuFlash to control boost through the stock BCS? Or rather, are you using a Xede or something? You should give a LOT more details.
Anyway, 24-25psi seems pretty high for base wastegate pressure. Are you sure your setup that uses Vishnu tuning doesn't have a special boost hose and restrictor pill designed to raise boost artificially? If you have something like this, then it should be expected that your minimum boost is that high.
Another thing is that you don't TIGHTEN the turnbuckle if your base pressure is too high, but rather loosen it. However, I'm not so sure it's the WGA's fault, because I think it's your boost system modifications causing it. If you loosen the WGA too much, then the spool will be very slowly and unresponsive. If you tighten it more, it will raise the base pressure.
Let me understand this better if I tighten the turnbuckle more, I will raise the boost pressure more? So maybe I should take out the Passive Boost Solenoid Emulator?
Yup, you are 100% right, very good advice. Well right now I had to zero out the boost table and I am still spiking the boost to like 25 psi thats with partial throttle, I am NOT trying to go through the gear with me boosting 25 psi. I tell you this with Forge WGA the car the MORE responsive and even my friend noticed it, when I was just part throttling the car. Just to make sure, if I wanted to lower the boost spike I would have to loosen the turnbuckle, correct?
Yes, you loosen the turnbuckle to reduce the base wastegate pressure, but you don't want to do that until you've set your entire boost system back to stock and set your boost tables back to stock. Then, if you see it raise to 25psi, be sure to let off and start working on the WGA. I don't think you should start by loosening the turnbuckle, because I'd be surprised if you had it too tight. You'd have to have it WAY DOWN with the opening of the turnbuckle well below the WG flapper pin for it to be too tight. Usually, people have it too loose, and if you are right on the money, I don't want you to end up too loose with a car that spools slowly.
As for it being a good mod, I have been waiting on one for months. Even being sponsored, I can't seem to get one, because they are out of stock and haven't received a new shipment yet...
As for your "spike" I run an MBC and with the forge wga I have almost no spiking compared with stock wga, now it seems to control boost much much better I just have to find the fine line between slower spool and too much boost, but at street level I hit 19-20 psi by 3500rpm and do not taper till around 6800 otherwise my boost curve is flat from spoolup, unlike the stock wga, and i am at high elevation. So play with wga setting first, with boost control zero'd out.
No, don't zero out the boost table. Set the boost tables to STOCK.
As for putting the arm on the flapper pin, you can either use a little metal rod with a hook at the end (like what the dentist uses to scrap off plaque ), or apply compressed air to the WGA nipple, which will push up the arm all the way in an instant, thus making it a breeze to install on the pin.
If the hole of the arm was way below the flapper pin, then you may in fact have it on way too tight.
cvnick
Aug 4, 2014 03:13 PM
DSMolition
Feb 26, 2014 08:14 AM
joeymia
88
Dec 20, 2009 06:30 AM
IceEvoIV
25
Apr 10, 2006 11:01 AM
