thread pitch and diameter of bell housing to engine block bolt?
i live on an a small island. none of the rink a dink hardware stores carry metric
so i order from nutsandbolts.com which by the way is a nice online store. they have scotch locks too if ur looking.
Almost every bolt on DSMs and EVOs is a 1.25 pitch. The tranny to block bolts are mostly M10x1.25s, IIRC. In general, bolts with 12mm heads are M8x1.25, 14mm heads are M10x1.25s, and 17-19mm heads are M12x1.25. This only applys to stock bolts. Hardware store bolts typically are 1mm larger on the head size.
