ACT or EXEDY
ACT or EXEDY
hi guys
can decide which clutch would be the best for me
please help out!!!
ACT Clutch Xtreme Pressure Plates
Sprung 6 pad Copper Ceramic Race Discs
ACT Pro Lite Flywheel
Exedy Std. Triple Plate Cerametallic HD (Non Carbon)
i need something that holds up to 700whp
please help out!!!
please help out!!!
please help out!!!
Both will hold but only one of those will shift at high rpms. OVer 8000k rpm.
There is a lock out issue on some of the single plate ACT's. I like it a lot but they do lock out.
Maybe I am just lucky, but my ACT XTSS has only locked me out once and that was before I did the SS clutch line, removed the restrictor, and adjusted the clutch. I don't know which one helped the most as I did all three at once. Then again I have never shifted above 8000 RPMs.
1 Post
Exedy Twin Cera/metallic will make you hate a normal drive. Hope it's your weekender!
But hey, this debate is years old. Learn from experience --- I paid 1200 for an Exedy twin --- hated life with it --- and now I've got an ACT --- no issues.
Could be the other way around for you, or not.
Good luck!
Good luck!
