stock ix fuel pump vs. walbro 255?
i've read that the stock ix pump has a higher flow rate that the viii's.
not sure if this is true or not but has anyone done a flow comparison or a stock ix pump vs. the standard walbro255 pump that everyone uses?
thanks
thanks
I am pretty sure AMS did a test on this. yes the IX pump outflows the VIII and is good for almost all the bolt ons i would say.
The walbro outflows the IX by plenty, as 500whp+ setups use a single walbro.
So it goes viii < IX < Walbro
thanks for the info.
i'm doing nasa time trials and could really use the points that they ding you for on the pump. but i don't want to grenade the motor for the points either
great threads. exactly what i was looking for.
i did search but didn't come across these threads.
so one last question, now that i know what the pump flows how can i tell what the max hp i can run safely at that rate is?
do i just go by the injector duty cycles * injector CC's to figure how much fuel it's moving and just make sure there's a bit of headroom on the injectors and the pump?
thanks again
thanks again
thanks but this is sort of a special situation and has nothing at all to do with money. actually i have one in the car already but i really need the points back to run the tires i want and still stay in my class. so i'm just trying to figure out if the stock pump can safely cover the hp level i'm at.
twinturbogreg
Sep 28, 2010 03:00 PM
