Boost problem
Boost problem
Ok here is what is happening
Ok so i have my boost set at 21 psi just for daily driving (93 octane). no problems always boosts great.
2 days ago i started to get a few things changed on my car to take to the track. I changed out my BOV. i use the forge rs for in town driving because i like the sound. I replaced it with the Evo 9 BOV. Got it in, took the car out got in third gear, then WOT it boosts at 28 PSI and stays there til i let off the gas. I freak out, pull over and turn the Forge MBC down 10 clicks. Take it out drive it again and boosts at 16 PSI, after a few more test drives i end up turning it back up 10 clicks and it boosts right at 21 psi. I thought it was a fluke..
Today i do a boost leak test, find 5 boost leaks, tighten the clamps down and get all of them fixed except for 1, which is a leak between the turbo and the Lower intercooler pipe, i think it is the gasket cuz i have the bolts tightened dow all the way ( i checked for tightness). it isnt a hugh leak but enough to loos 10 psi in about 20 seconds on a boost leak test.
I put everything back on take it out and drive it. get it in 3rd gear, then WOT and 28 PSI AGAIN. turn the MBC down 5 clicks then it boosts at 18 PSI, take it out for a few more test drives and end up turning it back up 5 clicks to boost at 21 psi.
Well i got it to the track today. Last tiem i was there i ran a 12.5 at 24 PSI. I turn up the MBC 6 clicks, run down the track at 23 psi and get a 13.8.... SO i take it back to the pit, turn up the MBC 2 clicks. take it back out and i watch my boost in every gear. this is what i was getting... 1st gear - 24 psi, 2nd gear - 22 psi, 3rd gear - 20 psi and 4th gear - 23 psi. and ran a 13.3 in the 1/4 mile.... WTF!!!
I have no clue what to even do, i ordered a new gasket for the turbo to LICP, but i dont know if that is what is causing this or if my MBC is going out. All my hoses are tight between the MBC and LICP, also i checked the hoses between the MBC and the BOV...
Any ideas?
Any ideas?
So, tell us, why exactly you switched from the Forge RS to the MR DV? Isn´t there a way to adjust the RS via different springs or an adjustment knob?
I´d think that the move to the MR DV is a downgrade. I wouldn´t trust the MR DV to hold very well for high boost levels in racing applications. The example that I have used to start leaking at 11 PSI. I have since crushed the thing and it holds better, but it cackles and flutters audibly.
I was told by AMS Performance that the stock Evo 9 BOV is the best BOV out there right now. I told them i race my car on the weekends and that it is also my daily driver. They said that the stock Evo 9 BOV holds boost great and is a great BOV and after using it i agree completely.
Also I havent done anything to my car in two days now, i got in my car this morning and was getting on the interstate, i was in third gear and floored it and once again it boosted to 28 psi... i have no idea what i going on with the boost problem i am having but i dont want to drive it anymore until it is fixed i am afraid one of these times it is going to seriously hurt my engine
elhalisf
36
Nov 19, 2012 02:06 PM
Chukee_R
17
Jul 2, 2007 02:03 PM
TonyG
18
Apr 2, 2007 09:59 AM
