Evo IX with Aquamist HFS-5 kit and 25 psi pump gas
This car was a Stage III Evo IX dumping 02 housing stock turbo - cosworth cams and 50/50 % water and meth on the lovely Aqumist HFS-5 system at 25 psi of boost
Car was running very well - zero knock
Today we are going to remap the car with 100% meth to see the gains / losses as compared to the water / meth 50/50% mix
Al
Al
![](http://i59.photobucket.com/albums/g316/DynoFlash_Evo_8/HFS-.jpg)
What is the difference in power between 50/50 and 100 meth. Also did you have to change the timing alot of a little between the two mixtures.
I found that my car ran richer with 50% water and it needed more timing. I felt power went down even with more timing. I prefer not mixing and simply running 100% of meth or alchy.
I hop this thread stays clear of flames like the other recent METH threads. I wish there was a way to make a thread and block whomever you didn't want posting in that thread. It would add a whole new element to posting in general and force peopel to be nice or baned from posting in certain threads.
When using a mix of water and alcohol I find it is possible to me more lean and mean in the a/f target than on 100% meth as the water absorbs a huge amount of in cylinder heat
We did not finsih the car today on 100% meth and higher boost as there is something loose on the exhuast or chassis which is making noise - tomorrow is another day !
once again one of the best tuners making great safe numbers and 25 psi of boost is nice because one bad tank of gas or something stupid can lead to a big BOOM, its nice to have a good margin of errror. nobody will touch my car except the man AL himself!!
