anyone with a 4g64 + 4g63 evo head?
Hi
any of you guys have a 4g64 bottom end mated with your 4g63 head with STOCK cams? can you please post dyno sheets of your setup. im looking for something on a t3/t4 50 trim or gt35r, however any dyno sheets will help. it's very important that the dyno sheets of your head with stock cams.
Thanks!
Thanks!
this is with a 2L, so a 2.4L would make even a bigger difference (and so would a 35R):
this car was tuned before the cams, and again after. this datalog lab dyno shows before and after a cam install...
The irony here is that upgrading to any of several popular cam sets is perhaps the most reliable, dependable means of increasing power potential available short of a larger exhaust and/or turbo. There are dozens, if not hundreds of examples of this scattered throughout this forum. The 4G63/4G64 responds to revisions in cam profiles rather well (even in largely factory trim), and improvements in power of >10% over the factory cams are not uncommon at the 300-400hp level.
wow, the peak numbers dont change much, but damn the entire powerband see's a gain. what cams were those?
i currently have a gt3582r. i was trying to make up my mind whether to throw in cams on my built motor(4g64 block + crank w/ 4g63 head) or not.
what cams do you guys recommend?
rpm_ruffryders
Lancer Engine Tech
603
Mar 3, 2020 07:04 AM
Ichigo0Soul
May 23, 2016 09:02 AM
bryonboals
Jan 20, 2012 12:36 AM
