How would I go about attaching a nipple to my 35r compressor for an mbc connection?
How would I go about attaching a nipple to my 35r compressor for an mbc connection? Where can I purchase a nipple to attach to my 35r compressor. Thanks.
Just go to a good hardware store and get a 1/8 NPT male to 1/4" barb male 90* elbow brass fitting. Remove the compressor housing or stuff a rag down into the discharge outlet. Drill a hole with a size "R" bit. Thread it with a 1/8 NPT tap. Apply a bit of Loctite, Hi-temp, liquid thread sealer to the threads and install. You should be ready to rumble.
No. But, that's how it is installed on the Piers Diesel Research Holsett HX-40 turbo on my Dodge. And it is how I would go about it myself. If you are squeamish about tapping your comp. hsg., then you could JB Weld the brass fitting after drilling. Alternately, if you don't want to mess with your compressor housing, then you could weld a nipple onto your UICP.
Depending on where you are located, there are a ton of turbo shops that can do this task for you in a few minutes, such as: Precision Turbo & Engine(Harry Hruska), Limit Engineering(John Craig, AZ), Blouch Turbo, Forced Performance, Full Race, Majestic, Turbochargers.com, Piers Diesel Research(WA), etc.
galantman03
43
Feb 5, 2017 09:54 PM
Flyhigh
Nov 29, 2016 04:10 AM
steevo
Mar 2, 2010 09:29 PM
