N-Tercoler Intercooler chiller
Nitrous oxide is a terrible greenhouse gas (many times worse than CO2 or CO). Not to mention it's flammable. Don't vent it to atmosphere...
Hopefully, you keep your CO2 tanks at room temperature. Overheat them a little and BOOM!
Why not just use compressed air? Much cheaper gas. There are cooling systems that use that already (not for cars).
Any compressed-gas liquid tank needs to be handled and filled with care. They should be left with some space inside for thermal expansion. If over-filled with liquid, they can indeed explode from expansion if they get warmer, since liquid is effectively non-compressable. Any good nitrous bottle will have a pop-off safety valve incorporated in it.
Compressed air (like from an air compressor) is usually in gaseous form, not liquid. If it was compressed enough to be liquid, I wouldn't imagine it would be any cheaper than CO2. Liquid CO2 is really cheap!
--Dan
Mach V
MachEVO.com
I have not seen many CO2 fire extinguishers heat up and go boom. To that end, I am working up a proto type using a previously owned extinguisher tank (check your local fire extinguisher service, they refill'em too) and soleniod controled valve (any good hardware supply Co.). My materials list is around 100 bucks and uses copper tubing and modified lawn sprinkler nozzels. Not to worry, I am tucking the tube "halo" behind the front facia so I won't embarrass anyone with my kludge.
hehehe, i cant wait to see pics! pretty innovative arent ya
Originally posted by Mach V Dan
Nitrous oxide is not flammable. It supports combustion, as WildRice points out. But it doesn't burn on its own.
--Dan
Mach V
MachEVO.com
--Dan
Mach V
MachEVO.com
I always was wondering what would happen in the event of a major impact from a collision
Somewhere on the 'net there's a site about some guy who hooked his nitrous kit up wrong, so the bottle heater could be left on even when the key was not in the ignition. Then...he left the heater on. Then the tank exploded. It split the trunk of his Maxima open like a banana. Parts of the car went through the garage door.
Moral: Read your install instructions.
--Dan
Mach V
MachEVO.com
--Dan
Mach V
MachEVO.com
Originally posted by designmanfx
hmmm... wish i had time to explain, oh well, w/ that system i'll probably be one of the safest evo on the street from detonation.
RIPP actually is using use on their car instead of an FMIC. I talked to him yesterday and he said the temps are CRAZY cool and works better than the FMIC he was using. I think I am going to set this system up on my galant SDS
Originally posted by Secret Chimp
for your viewing pleasure.... this is what an exloded 15lb nitrous bottle will do to your car.
not pretty....
SC~
not pretty....
SC~
Do we have any details on how the Nitrous Bottle exploded? Bad manufacture? Incorrect usage?
--Dan
Mach V
MachEVO.com
