Evo IX, stock turbo, Aquamist HFS-5, 30 psi. Dyno Results.
Back to work
why didn't you install the head studs prior to all of this?
head studs and FP should be a MINIMAL requirement on ALL EVO's running 20.5psi or higher to reduce risk of head lifts, lean outs, stretched this and that, etc. . . .and labor for that is only $100 and another $100 for the bolts - $200 for security. . .let's hope for the best. . .
I would still do a leak down and compression test just to see if everything is ok. Even if you put head studs in the damage might already be done to the head gasket.
I would also do some logging on the street with the car when it has a bigger load than the dynojet to see how the tune is.
You should be able to run 22-23 psi on the stock turbo on the stock head bolts just fine.
I believe Sean Ivey is at his current power level(550whp) on the stock headbolts, so I guess its hit or miss.
The advantage of studs has little to do with how much boost is run, but rather how much torque is generated. A larger turbo car that makes less torque, but more hp at the same boost pressure is not going to present the same stress as a car with a small turbo, and with a bigger torque figure. Greater torque equals greater cylinder pressure.
Nextly, a proper test to evaluate the potential of the injection is one that makes a comparison at the same boost pressure (let's say 25 psi or so), then with the injection activated, makes changes to the ignition map to see how much further the ignition values can be advanced vs. the regular pump fuel settings, and overlaying those two dyno charts. Otherwise, making one test at one boost pressure and the other at a different pressure muddies the results.
Update:
I drove the car home an 1h and 10 mins home from turbotrix last night with aggressive driving, cruising, etc and the car drove completely fine. The power delivery was great and there were no hesitations or anything. Most importantly there wasn't any white smoke coming from the exhaust. AFR's were in the low 11's.
I slapped in ARPs today. The install went nice and smooth.
I'll be cranking the boost back up to 28-29 psi. I'll be logging a couple things to see if everything looks ok.
Wish me luck
Wish me luck
I've been driving the car a lot to make sure everything is ok and this is me when I get on the gas pedal------>
I checked the overflow a few times after a few spirited runs and there were no problems whatsoever.
The car feels really fast. I love it.
You just heated up a little. What ratio of coolant to H2O did you use?
Next time try straight distilled water with 8oz of Redline Water Wetter
If it gets hot again turn the heater on all the way up, the fan to high and even turn the compressor on to get the second fan spinning
