what is the easiest way to drain fuel tank?
Old Sep 6, 2007, 06:34 AM
Aby@MIL.SPEC's Avatar
what is the quickest & easiest way to drain a evo 8 fuel tank?
i have the stock fuel rail / plumbing too.
Old Sep 6, 2007, 06:35 AM
Lancematic's Avatar
Disconnect the fuel return line and let it drain while the car is idling.
Old Sep 6, 2007, 06:38 AM
^ thanks, without looking at the engine bay right now, is the return on the drivers left or right side of the fuel rail?
can i just hook up a 3/8 fuel line to it or do i need to fab something up in order to connect a hose?
Old Sep 6, 2007, 06:39 AM
Rez90's Avatar
why are you draining your fuel?
Old Sep 6, 2007, 06:53 AM
Joshs EVO's Avatar
1. Standard Garden Hose
2. Your mouth
3. A whole lot "O" suckin
Old Sep 6, 2007, 08:36 AM
griceiv's Avatar
...the drain bolt on the bottom of the gas tank?
Old Sep 6, 2007, 09:47 AM
AlohaEvo's Avatar
+1, dont forget to get both sides...13mm bolt
Old Sep 6, 2007, 09:55 AM
derangedazn's Avatar
A match
Old Sep 6, 2007, 02:55 PM
i need to do some cam compares/car acceleration testing....so i want similar gas quanity in the car....the air got cold all of a sudden & I want to get some good comparison data...i just filled up last night
Old Sep 6, 2007, 03:02 PM
fimotorsports's Avatar
its 12 mm on bottom of the tank, both sides
Old Sep 7, 2007, 01:18 AM
AlohaEvo's Avatar
really..damn I must have a lot of grease and what not down there. When I did it and the 13 fit I was thinking that was an odd size to use...lol
Old Sep 7, 2007, 01:02 PM
evo9hu's Avatar
Yup The 2 Bolts Under The Gas Tank. I've Drained Mine Before And Thats Were I Drained It From.
Old Dec 10, 2012, 08:34 PM
silverevo05's Avatar
Anyone else drain there tank like this??? I've looked and cant find the 2 bolts
Old Dec 10, 2012, 11:08 PM
barneyb's Avatar
Someone said that if you pull the tank drains, gas runs along the underside of the tank and goes everywhere.
Old Dec 10, 2012, 11:16 PM
k_sheanh91's Avatar
I've drained from the bolts under the car a couple times and it works perfect. They're easy to find, pretty sure they're the only two bolts under there. It was only a small amount and some only came from the drivers side, non came out from the right side. After you've done that, disconnect the fuel line from the rail, its 2 10mm bolts or something. energize the fuel pump relay with a paperclip and it'll pump everything out the lines also.
Quick Reply: what is the easiest way to drain fuel tank?
