FP Evo Green Track Results- after the 487 whp results
Old Sep 14, 2007, 02:34 PM
Freddy302's Avatar
I hit Lebanon Valley Dragway in NY today, took off work to see what the FP EVO Green could do. It was about 80 degrees and a little muggy. This track is the “slower” track in this area compared to Atco and Englishtown NJ. But a track is a track.. So take in consideration this is my first time EVER racing an evo/awd car.. I drove it low on 93 octane gas and put three gallons of c-16 in it, on top of the meth injects.
Here is the orginal post if you want some back ground info.. https://www.evolutionm.net/forums/sh...ighlight=green
First pass spun the tires like mad with the stationary rev limter set to 6000 rpm
60ft 2.108
330ft 5.415
660ft 8.010
660mph 95.51
¼ Et 12.075
¼ mph 120.97
Second Pass Spun pretty good again, dropped the Rev limiter to 5500 rpm
60ft 1.878
330ft 5.011
660ft 7.565
660mph 96.8
¼ Et 11.59
¼ mph 121.68
Third Pass Lowered the Tire pressure to 21 psi (instead of 35psi) Thank you Kenny from proven performance for letting me know the best tire pressure!
60ft 1.685
330ft 4.721
660ft 7.239
660mph 98.32
¼ Et 11.230
¼ mph 122.34
Each Pass I shifted at 7k, But was going through the traps at 8k plus
Speed shifting on each pass, No power shifting.
On the track the car made a max of 27/28 psi and falling all the way down to 21 psi! ( I think I have to take a look at the WGA).
All in all I was very happy with the results. At the track there were a few new 2006 Z06 vette’s with slicks and bolt ons, Supercharged c6 vette’s, 2003 cobra (with big kennybell supercharger) Most of these guys were running 11.3’s-11.6’s (117-121 mph). I think the only car in that crew faster was a twin turbo vette that ran 11.1 @127.(they don’t say this track is a little slower for no reason) So the Evo showed up a lot of really freakin expensive Hot Rods.
When we get some really good weather I will hit one of the “faster tracks” and hopefully get that 10 second time slip with some more experience.
Old Sep 14, 2007, 02:37 PM
05WhiteEVO8's Avatar
Nice man , you are definitely moving. Is this a stock block car? What kind of clutch are you running as well?
Jeremiah
jhanksevo's Avatar
congrats nice times and a great improvement
Old Sep 14, 2007, 02:40 PM
Mitchubishievo's Avatar
That's some scary power for a green! Nice job at the track.
Old Sep 14, 2007, 02:41 PM
bluebyu36's Avatar
nice let's see the slips
Old Sep 14, 2007, 02:52 PM
Creamo3's Avatar
Nice times, what dyno did you run your car on? The traps seem a little low for the power level.
Old Sep 14, 2007, 02:58 PM
SuPeRNeT's Avatar
Great times!!! Really close to 10's on the stock ecu!!
Old Sep 14, 2007, 03:00 PM
evilempire76's Avatar
Nice numbers times! I'm sure theres a 10 sec. pass in her.
Old Sep 14, 2007, 03:04 PM
mumbles10's Avatar
not bad... keep at it and your times you want will come
Old Sep 14, 2007, 03:06 PM
electricevo's Avatar
Nice man, Im heading to the track next weekend with my green. I hope i do well too!
Old Sep 14, 2007, 03:09 PM
mplspilot's Avatar
He made the power spiking 35 psi on the dyno. It's for bragging rights, that's not what he ran at the track. He had 28 psi there.
Great numbers nevertheless!!! Can't wait for my green to arrive.
Old Sep 14, 2007, 03:23 PM
Duby's Avatar
those are sick power numbers for a green. congrats on the timeslip too
Old Sep 14, 2007, 03:43 PM
Freddy302's Avatar
Thanks guys! I am really impressed with the Green.. I just want to see if there is an way around the boost tapering issue..Here is the time slip
Attached Thumbnails FP Evo Green Track Results- after the 487 whp results-11.230-122.jpg
Old Sep 14, 2007, 03:51 PM
bluebyu36's Avatar
nice i belived you i just like to see slips congrats on the time,i just ran an 11.9 at 116 with a white rabbit tme turbo on pump gas im getting methanol and a tune for 28-30 psi(built block)and i hope i get your numbers....
Old Sep 14, 2007, 03:52 PM
JordanS4's Avatar
props for getting out there and backing up the dyno numbers. 122 is moving for that turbo! good driving for the first time out as well.
Quick Reply: FP Evo Green Track Results- after the 487 whp results
