gear shifting with aircon on...
Old Jul 8, 2003 | 02:03 PM
350ZTrack2Evo8's Avatar
hi guys, i cant seem to shift smoothly with the aircon on, its always jerky when i shift. Is it just me?
Old Jul 8, 2003 | 03:28 PM
Thoe99's Avatar
Same here, but I'm a newbie manual driver .
Old Jul 8, 2003 | 03:32 PM
zupber4930's Avatar
I've been doing man trans for years....gtta admidt...EVO VIII is rather touchy when the A/C is on when shifting....worse then it is if you don't let the car warm up for 2-3 minutes before you take off first thing in the morning
Old Jul 8, 2003 | 03:44 PM
EVO SPECIALIST's Avatar
Same here, just the nature of the beast!
Old Jul 8, 2003 | 03:46 PM
nastea's Avatar
i have no problems
Old Jul 8, 2003 | 04:19 PM
totaleuge's Avatar
same here. more jerky with AC on.
Old Jul 8, 2003 | 04:24 PM
nightrider4's Avatar
its because the AC lowers your Hp noticeably and that causes you to have to put more gas in with the clutch whih you are not used to causing it to be jerky since there is not enough gas accommodating the clutch.
Old Jul 8, 2003 | 04:25 PM
kidnice's Avatar
Noticed it here as well.
Old Jul 8, 2003 | 05:55 PM
aZnLaNcEr's Avatar
lol luckily i rarely have to use air con since i am sf. hopefully using the heater doesnt kill my hp
Old Jul 8, 2003 | 06:16 PM
wmcorcor's Avatar
This is common on all cars, especially turbo cars. I usually turn it off until I'm cruising unless the conditions demand AC.
Old Jul 8, 2003 | 06:36 PM
Trbo Dad's Avatar
I have noticed also. It is because the RPMs drop faster. Shift faster with the AC on and it is smoother.
Old Jul 8, 2003 | 11:02 PM
RENN-ART's Avatar
something else i've noticed besides this is that when i have the defogging on (both regular and with the air to the ground combo) it seems the A/C goes on!!! it's noticably colder compared to the other settings!!
the A/C button doesn't turn on though, but i know that it's on! maybe just slightly, but it's definitely on!..
i wonder if this is just my car!..
i can understand why it would turn on though as a practical matter when your windows fog... cus i know i've turned on my A/C in the past in other cars to help get rid of fog sometimes...
Old Jul 9, 2003 | 03:14 AM
neilschelly's Avatar
Read your manual, yes the defogger turns on the AC. I think that's common on many, if not most cars. My old '91 Mazda 626 didn't do it and it's the only car I've ever known not to use the AC in the defogger.
-N
Old Jul 9, 2003 | 08:04 AM
wmcorcor's Avatar
The AC takes the moisture out of the air which speeds up the defrosting sysle. This is commmon on most cars to have AC come on automatically in defrost.
Old Jul 9, 2003 | 08:13 AM
boostedwrx's Avatar
Yea, you have to clutch out FASTER when you have the AC on. If you clutch out slow, the car will shake when your disk finally makes full contact.
It seems like there is a lot more load on the clutch when the ac is on. The effect can be reproduced if you have 2 or 3 passengers in the car =)
