EVO 9 HKS cam=hollow??
I just got a set of HKS 272 cams for my Evo. To my suprise, the intake cam is hollow just like stock Evo 9 unit. No engrave on the intake . The exhaust side is a solid piece and have a HKS engrave in it. So is HKS regrind the stock Mivec cam??
i've also seen this in the only set of HKS mivec cams i've installed. it had the same markings as the stock cam did. my assumption was it is a regrind, or more then likely it is a blank from the same manufacturer as the stock cam, but ground to HKS' specs.
Ok, so I'm not the one off then. I bought my HKS cams from Nolimit. It's could be factory blank, since it's kinda early to have the Mivec regind. Anyway, I thought that's pretty cool to have hollow cam like the stock unit.
I wish these cammed EVO9s would start hitting the track. I've only seen not so hot dyno plots or something that wasn't a true before/after test. If the cams produce start to finish power cammed 9s should be at least .2 quicker and a few mph faster than non-cammed 9s.
InsanePain143
Oct 26, 2013 06:51 PM
