Evo 8 Mr Vs Evo 9 Turbo?????
Old Sep 28, 2007, 01:49 AM
Sxhawnn's Avatar
how bout a tme turbo? i just bought a tme, is a Ix turbo significantly better than a tme?
Old Sep 28, 2007, 01:54 AM
Boost3dxEvO's Avatar
So tonight I FINALLY did the swap!!!! It took a sh*t load of hours to do the swap though ) : I worked on it from 8 tonight until 4 30 this morning.. but it is finally done!
I added precision 680cc injectors, ix turbo, and dnp tubular manifold. and I replaced my RMR licp up to the turbo w/the AMS licp that bolts up to the evo 9 pipe off of the turbo!
and OMG WOW... i am absolutely AMAZED by the gains seen.. and then car isn't even tuned for these new mods.. I am having MELLON do a new map for me so I will be making more power... so MELLON FTW!!! but I got on it about 3 good times to make sure everything was working with no leaks .. and it pulled sooo much harder..
oh btw . I'm going to attach a picture of my turbo (IX is on left vs VIII on right)
The IX turbo is much BIGGER than my 8 w/10.5 hotside!
Also... don't fall for the whole "you need the evo 8 install kit" I just retained my factory evo 8 lines and went with the evo 9 pipe off the turbo w/AMS licp
CHEERS!!!
Old Sep 28, 2007, 11:12 AM
Ang Wen Yan's Avatar
TME is a standard TD05 with 10.5 hotside and ti/al exhaust wheel.The compressor housing is same as 8 one.
tim85851
Apr 2, 2011 02:01 PM
sphinxof2006
May 5, 2010 09:06 AM
xmaciek82x
Midwest Region
Oct 17, 2009 09:07 AM
Lucas03ES
Lancer Aftermarket Forced Induction Tech
May 2, 2009 08:46 AM
Devil_Evo
15
Oct 19, 2007 03:00 PM
Quick Reply: Evo 8 Mr Vs Evo 9 Turbo?????
