Looking to get green turbo
1 - 1515A057 Fitting, Air Output $37.91
1 - MR281085 Gasket, Air Output $2.74
1 - 1310A171 Pipe, Water Return $8.38
1 - 1310A248 Pipe, Water Feed $8.38
1 - 1225A042 Tube, Oil Feed $7.89
2 - MF660063 crush washer @ $0.79
2 - MF660064 crush washer @ $0.93
4 - MF660065 crush washer @ $0.57
1 - MN156738 gasket for the oil return tube on the bottom of the turbo $1.34
jason
I'm thinking very seriously about an EVOGreen. I'm torn between the choices for the hotside - 9.0, 9.8, or 10.5.
For a street-only VIII running straight 91 octane I'm leaning toward the 9.0 HS. What do you'll think? Would I be sorry later?
Would I even get enough out of a Green to be worth upgrading from my IX turbo?
You would probably be dissappointed in the Green eventually if you plan to stay on pump gas...........especially 91 octane. The Green shines in 23psi-30psi range. Not sure about the hotside............if you regret the 9.8 hotside, you could swap it with your current 9 turbo.
Might be boost quicker with smaller hotside. Stay with the 10.5
jason
jason
I figure to go for the housing swap. To complement the faster spool of the 9.0 housing I intend to install an Aquamist Alky kit programmed to spray a fine mist early, so as to further optimize spoolup. I'll also advance the cams up to +1/-1 in an ultiimate attempt to scoot through my close ratio JDM RS gearbox in a hurry.
I figure that with the alky, the 9.0 cm2 housing, and the advanced cam timing, I can get the Green to 22# by 2700-2800 RPM and the alky'll let me carry that on up to a peak boost of about 26-27 PSI.
wow thats alot of things i never know
So guys Dose the green Push some good Hp on 91?? em i going to notice a big diffrent?? or should i waiti a littel bit and get a 50trim??
if i will get a green turbo al get the whole thing coz it will take me alot to uppgread my VIII from what i sow now??
So all am asking is i need a plan to go with?? thats all??
The Green is a great upgrade. Very comparable to a 50trim actually. You will notice a difference from your 8 turbo. The green shines up top though in the high boost range. GREEN + METH FTW.
jason
BTW, are you planning to delete the Xede?
The only fly in the ointment is that, AFAIK, Mellon doesn't do Email Alky flashes. So, what I'll probably try is having my friend, JR Simon, who tunes my XEDE, build me an Alky XEDE map and toggle back and forth between it and a zeroed out XEDE which defaults to my 91 octane Mellon flash, if it's possible(?). Or have JR build me an XEDE Alky map which uses the Mellon 91 flash as a base map. There must be a way.
For sure, I will first try the 9.0 HS with a Mellon flash, on a straight pump gas diet. Only when it is fully sorted out with the new mods on pumpgas, will I attempt to figure out what to do about installing the Alky kit and getting it retuned.
