5 speed conversion kit?
Shifter base, shifter cables, shift linkage bracket, tranny side mount, 5 speed sensor harness.
The issue is that the shifter base is sold in pieces from the dealer. Shep puts it together for you and makes sure you have everything you need.
You could probably get everything you need off a wrecked evo, but I would just get it from shep and save the hassle.
I recently did the swap, its not too complicated. You don't need the center console either, the shifter boot is just a little looser ( I prefer it). Also the transmission harness is not needed if you go to the junk yard and pick up the same connector end and just re-pin the harness you have to make it work for the 5spd reverse sensor. If you need a parts listing I have one available, as well as the manual on how to put it together.
Blake
Blake
Blake
OneCrzyEvo21
Jun 9, 2016 10:12 PM
WTB[West]: 5 speed conversion kit
Paulevo9
Oct 28, 2015 08:51 PM
5spd, 5speed, conversion, convertion, evo, kit, kitevolutionm, needed, package, parts, spd, speed, swap
