6 hour turbo back install... need some advice
Old Oct 4, 2007, 07:38 AM
boostedwrx's Avatar
Listen to others.. PB Blaster and let it sit for a while. You should be able to take it off with an open end wrench.
Old Oct 4, 2007, 08:31 AM
thebluesky's Avatar
Wow, a lot of advice coming here. Here's mine. It sounds like you're about to strip the threads on the o2, which would absolutely suck. If you can, try to save yourself some heartache and buy a new sensor now. If the other one comes out fine and not exposed to liquids (the pb blaster and wd 40) on the sensing element (this will ruin the sensor) and the threads intact, then you'll have a spare which you'll eventually need later.
Old Oct 4, 2007, 08:33 AM
apagan01's Avatar
i wouldnt cuto no o2 sensor ,,, i get a nice strong snap on open wrench and PB blaster from wallmart and spray it let it sit for at least a day or 2 you have to let the spray to sit otherwise you aint doing much it has to wick into the threads
Old Oct 4, 2007, 08:53 AM
Former Vendor
IA Performance's Avatar
I would soak it in zep or pb blaster and then for a few hours and then come back and work on her. my O2 was a pain to take off as well
Old Oct 4, 2007, 08:55 AM
evolved83's Avatar
mine was a pain as well
Old Oct 4, 2007, 09:44 AM
FullOutPwr's Avatar
Thanks for the replies. Tried it with the 3/4 impact again before I cut, it twisted the 02 sensor into about 40 different pieces... and the bottom portion of the 02 sensor is still in the stock exhaust.
I had my car up on jack stands for 3 days and was soaking everthing in PB Blaster from the get-go. This wasn't my first exhaust install, however was the first time I couldnt get an 02 sensor out.
Old Oct 4, 2007, 09:45 AM
VenomEVO8's Avatar
PB BLASTER is your friend.. soak it and let it sit for like 2 hours... it will come off
Old Oct 4, 2007, 09:49 AM
FullOutPwr's Avatar
Read above post
Old Oct 4, 2007, 12:55 PM
Soon2BEVO's Avatar
I ninth the PB Blaster idea - that stuff is great
Old Oct 4, 2007, 12:59 PM
DG Motors's Avatar
trust me, pb blaster and a 7/8 wrench or 22 will do the trick...soack it up...if possible..u might want to heat it with a torch of some kind, just watch out for the wires.......
Old Oct 4, 2007, 01:26 PM
pog0's Avatar
I used PB Blaster to get mine out. Mine was like stripped from factory. Replaced turbo back in 3 weeks. PITA!
Old Oct 4, 2007, 01:27 PM
Roast Beef's Avatar
its a 7/8th not 3/4ths, theres your first problem...
When I did mine it came right out with a 7/8's closed ended wrench (I disconnected the wire to get the wrench over it).
Old Oct 4, 2007, 01:38 PM
funevo's Avatar
PB blaster works wonders, but a good trick that works 90% of time is to heat with a good torch (oxy.acet) the bung. But dont let it sink in to the o2, while its hot try and remove, you are basically swealing the bung to release the o2 sensor. Sometimes you can heat, then cool and it will still breaklose. But try while hot.
Old Oct 4, 2007, 01:42 PM
hmsevo9mr's Avatar
PB blaster a hammer and a 19 or bigger open wrench did the job last weekend for me.
Old Oct 4, 2007, 01:52 PM
PC325xi's Avatar
i had the same problem with my o2 sensor, i just unplugged it from the harness, brought the cat with the o2 sensor still stuck in it to a shop, and paid them 10 bucks to take it out for me.. they ended up getting a torch and heating it up a little first. then they just used a regular wrench and it came out. now the o2 sensor is back on my test pipe and i have no cel.
