EVO IX redyno 364whp new run 12.1@113
Old Oct 14, 2007, 04:41 PM
  #31
BoOsTinGEVO190's Avatar
Originally Posted by Soon2BEVO
You guys are looking at the dynos too much. 113mph can be had with a 330-340whp car so I wouldnt look at the dyno too much on this one. The average 350whp traps between 113-115mph, some go 116mph, miniscule amount go 117+
Id worry about those trap speeds, not the dyno.
i dont care about whp i really dont nor do i care about tq every track is different no?? every condition is different no??
it was 55 at e-town sat night it was windy that play a factor no?? say wind is going against you that would not help
i mean i did a good lunch maybe different shifting will help different rpm maybe??
i know i did fast shifting NOT powershifting
  #32
Sean@Iveytune's Avatar
Sounds good to me!!!
I am sure with more aggressive shifting, it would mph more, but the cars all differ and you are on the stock clutch you may not be detecting all the slippage. Shift RPM plays a large role in the mph too because you can shift lower and actually increase mph on stock turbo cars.
Still damn good.
Sean
Old Oct 14, 2007, 04:43 PM
  #33
evoracingstar's Avatar
nice man. good time! i got pretty much the same setup as u.
Old Oct 14, 2007, 04:47 PM
  #34
Silver06evo9mr's Avatar
time is slow for the numbers. i dont have cams nor LICP and i went 12.3 and my shifting was slow. i could hit that with less mods.
Old Oct 14, 2007, 04:48 PM
  #35
i dont care what anybody says every track is different
i know i drove good to limits but maybe better shifting at different rpm i know i was not granny shifting for sure
Old Oct 14, 2007, 04:50 PM
  #36
Still damn good.
Sean
thanks sean
Old Oct 14, 2007, 05:09 PM
  #37
Evo23IG's Avatar
Okay, you see thats where the problem is you say COULD do it, doesn't mean you can really do it. Until you do make that pass, please stop bench racing. Plus it was windy there towards the end of the night, which can easily play in the mph run.
Old Oct 14, 2007, 05:14 PM
  #38
AlwaysinBoost's Avatar
Originally Posted by Jhero23
Too much mods, too much whp, too much boost for such a slow run. Good launch though .
I agree. I went quicker in my full weight 04 GSR w/SS&L with only mbc, K&N, MR BOV and a flash by yours truley. stock IC, IC pipes, stock turbo, stock cams, yada yada yada. pretty good 60' though, I wish I could have pulled a 1.6x on the stock clutch.
Old Oct 14, 2007, 05:15 PM
  #39
out of all the things you would say is licp how about fmic im sure you can do 10 sec with my car
Old Oct 14, 2007, 05:17 PM
  #40
Still damn good.
Sean
your right about not be detecting all the slippage maybe there was i just did not notice
Old Oct 14, 2007, 05:33 PM
  #41
SickSilverNLow's Avatar
nice #s......
Old Oct 14, 2007, 05:36 PM
  #42
gsrboi80's Avatar
Whats up man. I seen this car dyno today at ICS. It was a beast for sure. Nice ride man
Good Luck
Old Oct 14, 2007, 05:43 PM
  #43
mudduck's Avatar
I don't think anyone here is criticizing your driving (your 1.6 60ft times speak for themselves ); but I have to agree with others on here that a bolt-on, cammed Evo IX should be trapping better than 112-113...
No need to get defensive, instead try to figure out what , if anything, is the cause. Yes, I have seen slow tracks and days where people are trapping like 3-4 mph less than they do elsewhere. Just make sure 1) no boost leaks 2) no knock at WOT (or ECU will pull timing) 3) you are shifting at the optimal point for your setup... 4) no bad tank of gas resulting in knock
thanks for posting your results
Old Oct 14, 2007, 06:12 PM
  #44
Srt-4 Turbo 7's Avatar
Originally Posted by BoOsTinGEVO190
In 1/4 you look at whp not what your tq the reason you have 350tq its just a spike for a split second compare my graph to your graph with tq # starting let say from 4k rpm then compare 5k rpm 6k rpm 7k rpm is there a huge difference I bet not
Your graph (I did the best I could to make out the numbers, so there are not exact, just close).
3,000rpms - 210wtq
4,000rpms - 330wtq
5,000rpms - 325wtq
6,000rpms - 300wtq
7,000rpms - 260wtq
My graph
3,000rpms - 250wtq
4,000rpms - 350wtq
5,000rpms - 325wtq
6,000rpms - 300wtq
7,000rpms - 255wtq
So from 5,000rpms on our torque curve is very similar if not identical, with you holding roughly 5wtq over me at 7,000 rpms. But at 3,000rpms I have 40wtq more and at 4,000rpms I have 20wtq more.
Regardless Stan you had good runs, a great looking car, and you can drive it. People are getting way too defensive in this thread. And yes wind will affect your mph and so will your shift points.
Old Oct 14, 2007, 06:28 PM
  #45
EVIL_EVO_VIII's Avatar
Congrats on the new #s!!!!! Now ur right there with mine Time for me to hit the track soon I need a new clutch, my clutch was slipping last night at wot from a roll so im sure it wont hold up at all if i launch it
Quick Reply: EVO IX redyno 364whp new run 12.1@113
