Power Steering Fluid??
Today we flush the power steering fluid and the mech put this inside...
http://www.castrol.com/castrol/produ...tentId=6007760
It is ATF formulated... on the back of the bottle.
What power steering fluid u guys use if you can't get the Mitsubishi one
An automatic transmission fluid formulated and approved for the latest GM DexronŽ III specification. Also recommended in power steering systems in cars, light commercial vehicles and tractors.
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
1. Raise and support the front wheels.
2. Disconnect the return hose connection, and then connect a
vinyl hose to the return hose, and drain the fluid into a
container.
3. Disconnect the ignition coil connectors (Refer to GROUP 16,
Ignition Coil P.16-33).
4. While operating the starter motor intermittently, turn the
steering wheel all the way to the left and right several times
to drain all of the fluid.
5. Connect the return hose securely, and then secure with the
clip.
6. Fill the oil reservoir with GENUINE MITSUBISHI POWER
STEERING FLUID up to the lower position of the filler, and
then bleed the air.
container.
clip.
then bleed the air.
jaycee842
11
May 27, 2016 06:35 AM
mrMTB
41
Aug 14, 2009 10:45 AM
2006, evo, evolution, evolutionm, fluid, flush, genuine, ix, lancer, mitsubishi, oil, power, recommended, steering, stock
