Help please.......ABS/Speed Sensor help
After installing my clutch, I have a problem with my ABS sensor. All three ACD lights are on, the anti-lock light is on, and the abs light is on. From searching on Evom, I learned that the problem is with the ABS sensor - that it would cause each of the previously mentioned lights to come on.
I pulled the driver side, front sensor off and it is infact broken (wires are freyed). The problem is that the ABS/Speed sensor is on backorder from every Mitsubishi dealer that I have contacted (probably at least 5 different dealerships).
My question is, will it hurt to drive my car in it's current state? Will it cause any additional damage?
Im have pretty much the same issue here. My abs light went on and 10 min after that all 3 acd lights lit up. I was also wondering if this will cause more damage if i keep driving. Everything else seems to be working fine.
ok found out i need to change my rear left axle
Couple of the teeth broke off that the abs senses in order for it to work properly.
So now my q'n is, can i drive even tho all 3 acd lights light up after the anti lights up.? sometimes the acd doesn't even light up but thats rare.
Stevo9267
Feb 23, 2016 09:22 AM
DarkEvo
18
Oct 12, 2015 07:54 PM
