just switched from hfc to testpipe
Wow, I guess all those other "high flow" cats arn't really. there was ZERO difference between an open pipe and a 3" random flow cat. What type of media are those other "high flow" cats? With the random flow, you could see through the media as it was a honeycomb.
I'd like to see a test with one of the most expensive HFC's and probably only true one's like the APEXI HFC or the MINES HFC. Problems is, I don't know anyone willing to drop 1000 dollars on a 3'' wide 2ft piece of pipe.
CO doesn't have a smell. Therefore, you cannot possibly "love the smell of CO in the morning." However, I encourage you to experiment for yourself...you would do society a considerable favor by removing yourself from the gene pool
A cat is a quid pro quo item in terms of the environment.
On one hand using them makes you a law abiding citizen, and aids in maintaining air quality levels; but the use of it also emits more H20 vapor, nitrogen, and CO2 into the atmosphere--thereby contributing to the global warming theory.
Not using it, well, you don't contribute to global warming but you do emit poisionous carbon monoxide, hydrocarbons, etcetera into the atmosphere--making it just that much harder to stay alive.
HP at the expense of poison gas or a little less HP at the expense of having to sweat your ***** off in December...I think we're screwed either way. Might as well go for the HP!
anyone who runs catless on a street is a selfish *****.
eff the ozone, this %hit stinks.
every time I drive behind someone in a traffic I feel like I'm in some effing eastern europian country where they they drive in those retarded ladas with no cats and ahve 50 year life expectancy
