FP White Rabbit turbo
Depends on what you like. You buying this used or new? Prob for a little more money you can get something better, but I love mine. Its basically an FP Green Comp. wheel in a stock CHRA! I have the 8 WR and I love it. Try to find a 9 WR b/c it has the 9 comp. housing, but if not its still a great turbo, despite what others may say and w/ supporting mods can make close to 400 on pump.
There are 2 different WR. One is an 8 WR and the other is a 9 WR. Both are exactly stock looking except that FP stuffed a FP green wheel in the stock compressor housings. Its as close to the FP green as you can get w/out buying a FP Green.
Do a search and read the posts and look at the pictures so you can really understand the difference between the two. The WR turbo usually has an 8 compressor housing and higher flowing comp wheel. The comp housing is smaller than the ix compressor housing and has the same size hotside's.
I would expect an extra 20 whp if you are pushing around 23-24 psi, mostly due to the reduced boost taper. If you are only at around 21 psi, then you will see much less gain. Most of the advantage of the WR turbo is the fact that your torque curve won't dive in the higher RPMs compared to the stock turbo.
