Turbo XS Downpipe with aftermarket O2 housing
Has anyone ran a tubro xs downpipe with any aftermarket o2 housing? i have been told that the turbo xs dp won't work with anything but the stock o2 housing??
no, im running turboxs DP with ebay o2 which is practically same fitting w/ 90% of the aftermarket o2's out there... turboxs DP comes w/ their own donut gasket, stock gasket needs to be removed (probably baked onto the stock o2 so gotta rip it off haha)
Silver Sponsor
If the O2 housing you are buying uses the stock donut gasket then the Turboxs gasket will work. The only O2 housings I think will not work with the turboxs gasket are the Invidia and Works. Modification of the TurboXS gasket would be required for it to work with those O2 housings.
thanks for your help. I already ordered the o2 housing from buschur. I am hoping their o2 uses the stock donut gasket. I asked if them if their o2 will bolt up properly to the turboxs dp but they didnt really give me an answer(said he didnt know) anyone know what kind of gasket buschur uses or if it match up with the turboxs do?
i believe the early turbo xs dp's had this metal "top-hat" that required a larger donut gasket, as like the large donut thaty works uses for their custom o2 housing. the reason for this, turbo xs was planning to make a 3" dia. o2 housing, but they felt there was no merit.
eventually turbo xs started to make dp's that utilize the oem donut gasket.
i dont know when this change took place.
hope this helps you a bit.
i think everyone already gave u an answer but i'll rephrase specifically for the buschur. the buschur unit is a good "ebay" o2 which will fit in ur evo just fine w/ stock gaskets. now the gasket that fits between the o2 and DP will be replaced by ur turboxs gasket.
thanks for all the help. little worried bout everything working but sounds like it will!! catback, with a test pipe, dp and o2 are my first mods! i have had the car for over a year and finally saved up some extra money to improve. next on my agenda is a mbc and a tune.
FS[Northeast]: Turbo xs downpipe $175.00
17579EVO9MR
May 30, 2016 11:27 AM
afmafia
Mar 3, 2008 09:42 PM
Drill_Sergeant
Dec 1, 2006 12:26 PM
