Normal Blowby ????????
Ok question here guys , those who are running a catch can from the pcv port on the backside of the valvecover. The question is
A. How often do you have to empty the catch can due to it filling up with blowby residual vapor and what not??
B. What does it normaly look and smell like I know it seems weird right but I just wonder what the consistency is of it????
C. Also I use a filter on the breather port it is normal to see a slight bit of vapor out of it as well correct?????
At idle, you shouldn't see any vapor coming out of the breather port, the valve cover should be under a slight vacuum, pulling in through the breather port, and going on into the intake manifold. Unless y our catch can is causing a higher dp than the intake manifold is running at idle, you should always be sucking in through the breather port at idle.
I am not having what I would call alot coming from the pcv I have been using this way for maybe a month and it is just covering the bottom of the can with a hard to describe liquid , that smells like a combination of different things not just oil.
That is why I was wondering about what it looked and smelled like??
I would have to pour it into something to measure it and see how much I have accumulated so far in the 4 week span
it'll depend a lot on the weather.... When it's hot, any water vapor that's in the blow by (yes, water is a product of combustion) will stay in the vapor form and you'll never catch it. The only thing you'll catch is oil vapor/mist that condenses, and it shouldn't be alot. Once it turns cold, the water vapor will condense in the can, and your volume collected will go up. It'll smell like a$$, and turn a chocolate milk looking color.
I used to have it going to a catch can but had recently put the breather filter on it , I think I will buy another can and dump it into that again. I wanted to eliminat the pcv so I used the can for that instead
Johnboy1065
12
Feb 9, 2009 06:24 AM
VTEC Killer
13
Mar 14, 2005 07:47 PM
