possible failing water pump
recently my car has developed a tick at idle. From searching, I found others experiencing the same thing. It sounds like the noise is coming from the water pump/water pump pulley. I loosened the drive belt to check for play in the pulley and did have some side to side play. correct me if I am wrong but from what i understand, that pulley is fixed to a shaft in the pump and should not have any play in it what so ever. as far as the cars performance, coolant temps remain consistent(proper operating temps), no whine of dying pump, and no leaks. Any input would be great. thanks guys
tx evo
34
Nov 26, 2003 12:58 PM
