Gauge Dilemma, dont know what to buy....
So I am thinking of replacing the A-Pillar on my Evo with one of those triple gauge pods. They hold 52mm gauges. I was also thinking of going with the double pod that replaces the trim on the top of the steering column. I definately want a shift light so I dont have to look so carefully at the tach. I am thinking of going with this one from autometer.
As far as the other spots (I would have a total of 5) I'm not sure what to go with. The autometer tach/shift light is expensive. They sell them on ebay for about 170$ including shipping. I was looking at these "glow shift" brand gauges. Does anybody know if these are any good? I was thinking:
Shift light & Oil Pressure for the steering wheel pod. (this takes up 2 spots)
Possibly a Boost Gauge, A/F ratio, Fuel Pressure Gauge for the A-Pillar.
http://cgi.ebay.com/ebaymotors/03-07...spagenameZWDVW
Here is the auction where you can see the stuff I"m looking at..
Feedback is appreciated. - Also installation tips are nice if anyone has any for me...
That gauge looks a little tacky to me, perhaps it's just a bad picture. If it's just a shift light that you're looking for, why don't you just purchase a shift light and mount it somewhere in your field of view?
Having a gauge "mounted" anywhere will look much worse than this one. I dont want anything attached with brackets. I have seen this one in a flash demo somewhere and It only looks bright like that when it is lit up. It is dark when you are below your shift point.
Look for the raptor shift light. Pretty cheap and small and can be mounted anywhere. Personally, I think the triple a-pillar pod looks really bad and impedes your view way too much. I'd go with a dual steering column pod or center console pod.
http://www.raptorperformance.com/
I would buy defi guages...the two guages that are a must imo is boost and egt the third one is debatable ie fuel press or oil press. I would also get an AEM wideband too while you are at it. OR you can always buy a zextronic
defi is a very good gauge i have 3 of them on my pillar the bf red ones...im getting a steering column gauge now for wideband and egt but im stuck on which egt to get also...will probably end up going with defi though
Location: City O Sin, MA...the not so sinish part though...
I had autometer c2 gauges. Ricey as all hell but I liked the look at first. The 3 gauges reflect off the window at night and the 2 on the column block your fuel gauge and some of your tach and speedo. Its just not convenient at all. Eventually I got defi BFs(which I would not recommend because they're innacurate) and put 3 above the ac controls and 2 on the a pillar. Since they were black gauges they didn't reflect at all really and it was much more user friendly. I had 1 aem wideband on the column and it was a convenient set up. If I could do it all over again though, I'd go less gauges. You really don't need them all.
Your probably gonna do the 3 pod a pillar thing anyway so to answer your question...
Boost on column, Wideband 02 on column, oil pressure on pillar, oil temp on pillar, egt/fuel pressure(your choice) on pillar. Good luck
Have you also looked at Prosport gauges? Here is a link:
http://www.ultimate-cc.com/web/ProsportGauges.php
As far as gauges I think you need boost gauge, wide band, oil pressure, and EGT.
Nissan2Evo
11
Feb 29, 2008 12:17 AM
