solution to exedy single clutch chatter?!?
I wouldn't worry about it. I had the thick face cerametallic 4 puck from exedy. What shocked me was that the pressure plate gave out well before the actual friction material did. I mean, you've basically got BRAKE PADS working on the flywheel and PP, the spring in the diaphragm just gave up and wouldn't hold anymore. Did last me 30k miles though which was a plus.
You're stuck with it man. Just learn how to bring up the revs before you start letting out the clutch in first. Only way around it.
Randal
Nov 28, 2012 07:34 AM
boosted91t
30
Nov 28, 2011 07:42 PM
