So whats the trick? Oil pump sproket bolt w/race balance shaft.
#31
The suggestion in this thread to use an impact gun was focused on how to get a bolt to torque without being able to reach the backside easily. Impact guns can sometimes tighten bolts in these situations (think tierods that are spinning when you try to get them to start up the taper), but there's a huge difference between high strength suspension components and oil pumps.
There's no reason not to simply do it right. Take off the front cover, carefully immobilize the rear of the gear shaft, properly torque to specifications, put it back together. I probably don't need to remind you that (1) you should relieve the gear teeth alittle and make sure that there are no factory burrs of any kind on the back flat side of the gear before installation (2) you install the gears matching the dots, if they're on the gears, (3) you use lots of high quality assembly lube on the gears and shafts and (4) you prime the pump before you put on the timing belt and assemble it.
If you're interested in making sure you don't have high oil pressure issues, you also relieve the pressure relief valve on the back of the filter housing while you're doing this job.
Enough said.
Enough said.
#32
I had this issue once. I re-installed the old timing belt and properly tensioned it. The belt tension was enough to reach the specified torque (with a torque wrench) and it didn't jump teeth. Then I installed the new belt. I didn't use the new belt to avoid damaging it.
#34
bringing this one back up top. Even if you can get the balance shaft in a vice, the gears in the oil pump will still take the load when you tighten the oil pump gear nut, right? Is this ok? Or would it be better to rig up some sort of tool using the old timing belt and a strap wrench of sorts, so that the gears on the inside of the pump don't see the load when your torquing the nut down? If the gears can take 40 ft.lbs. of force, it's no biggy, but does anyone know for sure?
#35
bpdean
19
Dec 29, 2015 03:08 PM
My03evo
33
Apr 8, 2011 03:05 AM
D-VO
20
Sep 30, 2010 09:24 PM
GTVEVO
12
Apr 1, 2004 11:32 AM
