Drop-in replacement turbo options
#31
1 Post
Back from the dead ... what route did you go in the end, and did you ever get confirmation from PTE on the compatibility of the Garrett turbos? They are very attractive being dual BB and 2/3 the price of an FP Green. If it's not a direct drop-in, can somebody guess at what is needed to make it fit in an Evo?
#32
Dave have you ever seen this car??? http://www.mach2racing.com/
very nicely prepped RS200. with an aazing engine! they vent the BOV back into the exhaust manifold on overrun to act as an anti-lag. also they use a normal anti-lag system (retarding ignition timing)! you can onyl imagine what the two together are like! lol
from memory these gusy are running a 2.4 BDT Evo 2 engine with a custom turbos (deigned for altitude).
also their driver dosen't use O2! he thinks its for whimps! lol
Chris.
Chris.
FWIW, Stig's car was registered earlier in the year to compete, but they had to pull out because of problems sourcing engine parts or something like that. We're in the same run group as Monster this year, so again, we'll get to see that thing up-close and personal.
Dave
#33
I have a manifold that will work with DSM flanged turbos. It is a manifold from a Buschur cast manifold turbo kit. I don't have a use for it now as I have went with a Peakboost HVS system.
#35
I chatted with Robert from FP this afternoon (very knowledgable guy if you didn't already know ), and I think that the newly released FP White may be a good bet. It should be able to hold a bit more boost than the stocker, and hold it higher in the RPM band than the stocker and spool is going to be fast. He's got a few customers running cars in Colorado, so he's keenly aware of our needs up here.
I'll be sure to post up when I make a decision, both with the turbo choice, and the results.
Dave
#36
At altitude, the engine is effectively smaller, so even an FP Green behaves like a larger turbo, but without the power of a larger turbo. For a Pike's Peak run, the deficit will be much greater than in Denver.
At altitude, heat dissipation is reduced, so the largest FMIC that can be fit in the chassis is advisable. Think about a good oil cooler as well. The factory radiator may be ok.
A stock block is not the best way to go. For racing 9000-14,000' ASL, I'd be thinking along the lines of an 12:1 SCR engine, running 100% alcohol. I would pay special attention to maximizing the quench area of the piston, and of course, alcohol will generate less heat than gasoline. An AMS 2.3RR shortblock fitted with the high SCR pistons would be a good direction.
#37
The problem with any of options that aren't 'drop-in' is the cost. I'm planning on buying an easily swappable 30R (& 35R) kit to run on a high-compression stroker motor. The kit I'm leaning towards hasn't been released yet. We've been working quite a bit with AMS on our PPIHC build(rally brake kit, Ohlins rally suspension, diffs, intercooler, etc). The reason I'm looking for bolt-in turbos is that I don't want to spend the $$ twice on a big-turbo upgrade. Whatever I end up getting now (if anything), will need to eventually serve duty in my rally setup, which will have a 6k RPM effective redline, so instant spool is a must. I'm a picky SOB apparently.
Dave
Dave
also is there any reason why you dont want to go BIG?? if you are running a strocker and you will be using antilagand high comp, a GT40 might actually work well! also it will not have to boost drop off like the smaller units.
all im thinking is i have seeen Simon Norris (form Norris Designs) car with a GT42RS on there and it works GREAT for him even when he is thrashing it around verious tracks in the UK. there is NO lag and the responce looks increadably quick for such a big turbo! also RC developments have used these trubos in the time attack cars and they have proven to be VERY fast with little lag!
just thinking outside the box!
Chris.
#38
also Dave, have you had a look what the Ozies do?? they have a hill climb series like thePikes Peak and they run some pretty mena machinery.
think someone runs a Evo and there was one guy with a twin trubo flat 6 scooby (you dont see them everyday!!) lol
Cheers
Chris.
Cheers
Chris.
#39
Cheers
Chris.
Cheers
Chris.
In response to your previous post, we're running an AMS FMIC. Haven't seen any issues with overheating of the air, but after a run to the top, the IC is too hot to touch on the hot-side and fairly cool on the cold side. For PPIHC, I will be adding a water mister system which should make the IC act like its a bit bigger.
You guys are all spot on with the motor suggestions...and if you checked out our PPIHC build thread (link in my signature), our "ideal car" would have a 2.3 or 2.4 stroker, 10-12:1 compression and a 35R. I think the 42R would be just too laggy in the thin air, but hey, I might just try it if the 35R doesn't seem to big. Since the actual build costs on the car came out about $10k over budget, the motor and turbo were the easiest places to make cuts, so that's why we're on stock bits for the 2008 Race. In the end, running a lower powered car the first year will allow us to focus in on the suspension and handling instead of having to mess around with the ECU after each run.
Dave
#40
Dave its nice to see you are taking it easy on the power front! its very easy to shoot off and start making masses of power yet not beable to use it all thanks to a rubish setup. the fastest cars often have the BEST SETUP for the race! you can allways make a little bit more power, but gettting are car to turn better if often MUCH harder!
what do you run for brakes?? i have heard these can come under MASSIVE heat loads towards the top of the hill! they say alot finish with them not working and boiling fluid.....
Cheers
Chris.
Cheers
Chris.
#41
AMS Rally Brake Upgrade with the "B" compound pads, and stock brakes in the rear with Performance Friction 97 pads.
Good to know. My car last year had a short ratio dog-box in it, and we blew up 5th gear in it two weeks before PPIHC, and didn't have time to source a new one, so our top speed was ~80mph. I was running marginal brakes at best, but had a fresh set of Porterfield R4s on the car, and didn't have a hint of brake fade all run. I'll have to be a bit more mindful of the issues this year, as this car has a much higher speed potential.
If you have other questions related to my PPIHC run, feel free to post them up in that thread so we don't confuse people who are looking for drop-in turbos. I should be making some updates to it in the next couple of days with some modifications I'm working on in the heat management department.
Dave
Dave
#43
Here you go:
https://www.evolutionm.net/forums/sh...d.php?t=300029
Dave
p.s. link was also in my signature if you clicked on "Evo build up," and information from the group running the event can be found by clicking on the "PPIHC" link.
Dave
