i need help i cant get exhaust mani off to do turbo swap
i am replacing my viii turbo with a ix and i have everything completley unhooked tubo and o2 are just sittin there unbolted. I have all the bolts off the manifold and it wont come off for anything, it is completley apart from the turbo, its just stuck on the top studs. i have pulled it , wiggled it, nothing works. my car is an o3 so its been on there for five years. does anyone know what i can do to get it off, i really need an idea/ thanks alot guys
it doesnt wiggle, i soaked it about three hours ago and it wont budge, i also already tried beating it with a hammer, i hit it as hard as i thought i could without risking breaking the studs. i dunno i cant get it do even budge at all
Jack the car up, stick something under the manifold (long enough so it reaches the ground) slowly lower your car. Sounds dangerous...do this at your own risk and only if you feel comfortable about it.
Its actually easier to pull the whole entire manifold/turbo/ o2 housing up and out as one unit. Taking the radiator out giver u much more room but not entirely necassary.
Like previous post has said make sure you loosend up the bolt off the o2 housing that connects to the block.
If its not moving something is still bolted on somewhere
TREVORSEVOVIII
Nov 25, 2007 11:13 PM
