DB gauge Innovate not accurate????
my car doesn't that's gona stall though...I will try to check a boost leak then if not i will change my sensor. Im still thinking why when i shut it off and turn the engine on goes back to normal reading the whole time???
# 1
I would do a bost leak - pressurized bost system test on any modified evo as a matter of regular maintenance. A huge proportion of evos have boost leaks of some sort. The only way to find them is with a pressure test.
LM1 wideband sensors go bad
You MAY have a bad sensor - buy a spare sensor - they are cheap - and see what effect that has
# 3
exhuast leaks and exhuast manifold leaks can throw off 02 readings - make sure you have no pin hole leaks in the exhuast
Al
# 3
Al
Try their new firmware then do a free air calibration before you spend the money on the new O2. http://www.innovatemotorsports.com/s...re/lc1v110.dld
Bosch #17014
Bosch #17014
one thing i havent tried is resetting the ecu...not sure if you are supposed to do that each time you flash the ecu?
ill reset the ecu and see how my idle is then...im also having a boost leak test done wednesday
When we installed mine we had to make sure we had the proper voltage, and ground. I think it is an electrical problem by not getting proper voltage, try moving the wiring around to a better hot lead and ground to solid connection.
