fluttering at part throttle sometimes
I've noticed sometimes at part throttle when I let off the gas in like 3rd, 4th, or 5th I will get a very small and faint flutter sounds just like compressor surge. I have the stock bpv and a buschur racing cone filter I wondering is this is normal or what it could be. I only hear it maybe once or twice a week
thanks
thanks
yeah i have this going on for a while.... like say your crusiing on freeway in 5th(5spd)
and you just build like 5-6psi of boost by partial throttle, and then the bov starts fluttering like crazy until i either let off and gas more......if someone knows how to solve this that'd be GREATTTTTTTTTT!!!
its so annoying
its so annoying
its so annoying
its so annoying
Its normal part of the DV valve due to the pressure differences between the turbo slowing down and whats in the manifold makes the valve flutter/chatter/talk to you in sometimes its dramatic and short lasting and sometimes its softer and longer lasting. This is all normal operation.
its so annoying
its so annoying
it will definitely be worse in cooler weather as boost is easier to build in the intake piping while the intake manifold is at a much lower pressure since the throttle body is just cracked open, causing the pressure drop between the two. It's enough to open the bov.
