Going for 900whp this Week!!! Pics Inside!!!
#346
from what ive read you made 802 at 44lbs on the s372 and then made 904 at 47lbs on the larger 4202...so im not sure why you keep saying you got 100whp more at less boost...sure at the same boost level you probably made more power but not 100whp more...also i was wondering what cft had to say when you went to their shop to change turbos..they claim to have told you to get oil from another source
quote"They where here @ our shop the weekend of the War of the Imports and we told them that they were getting the oil feed from the wrong spot!
The EVO's have Oil/Lubrication problem from where they are getting the oil feed, which is in front of the head. Thats the last place on those motor to get oil, we check on our "Eligal EVO" and on that spot @ high RPM gets about 30-35psi of oil pressure!!!
Everybody knows that @ 9,000+RPM and @ 40+psi NO turbo is going to hold with 30-35 psi of oil pressure!!! "
I am waiting to hear back from bullseye but as i said i am 99.9% sure it is not an oiling issue.. I had someone look at the turbo locally that builds BW turbos for alot of guys in Puerto Rico and he also said it was not an oiling issue.. I would elaborate alot more on what we think is the issue but as i promised bullseye i would not post anything else til they looked at the turbo and gave me their input..
BB turbos do not require much more than 20psi of pressure IMO.. A very well known builder/tuner has assured me feedling the turbo from the head is no issue on my new setup..
#348
#349
Yeah, the BB turbo doesn't require much oil at all, so if it was an oil issue, it would not show itself with the Garrett like it did with the journal bearing BW. For what it's worth, i run my turbo with a -4 feed line from the block and run about 85psi oil pressure.
#350
and i was just replying back to the part in quote " NO turbo" will survive at 35psi of oil pressure.. again, ill wait to hear back from BW on their diagnosis but im confident its not oil related.. another reason why i know its not oil related is cause the 1st turbo had over 20 dyno pulls before it let go and it let go when we went up over 45psi.. the 2nd turbo last 2 passes at the track cause both passes were up over 45psi.. if it was an oil issue the 1st turbo would have let got at 20-40psi while we were pulling on the dyno on the 1st few pulls..
#351
its not an oiling issue tony trust me.. if it was the 1st turbo would not have lived 20 pulls while the 2nd made it thru only 2 track passes.. ill keep you informed when i find out bullseye's diagnosis.. thanks for the input though, i appreciate any advice i can get from you..
ill pm you with some information as well..
#352
#353
The 4202 is a bigger turbo, it should make 100whp more. The 4202 is capable of 1100whp, i've done it. The 372 is actually only about 70.8mm on the inducer, barely larger than the 4294.
I'm only trying to help, making more power at less boost is better all the way around.
I didn't read it all, but what were the details on the 372 (turbine housing and manifold) and on the 4202? I think i read that you changed the manifold setup with the 4202?
I have seen HUGE differences in power with different manifold/turbine a/r's. The common mistake everyone seems to make is a big compressor and choking the turbine size down too far because they're concerned with spool. Too small of an a/r will kill the VE of the engine and result in very high boost levels for the power being made.
Don't take any of this the wrong way, i'm not attacking you or telling you you're doing it wrong, just sharing what i've found in hopes of making your situation better in the future.
Hope you get everything resolve soon Mike@USP!!!
The car is sick !!!!
Fernando @ CFT
#356
I noticed somethin in the video that I was wondering about....the one where you busted loose on the dyno, I noticed that you oil temp guage was stuck on the peg...so im assuming either it wasn't hooked up or ....you get the idea....
keep plugging away it is gonna be a monster!!!
#358
AWD Motorsports
56
Jan 10, 2009 08:10 PM
AWD Motorsports
62
Sep 1, 2008 10:45 AM
AWD Motorsports
54
Aug 8, 2008 08:47 PM
AWD Motorsports
90
Aug 1, 2008 01:22 PM
AWD Motorsports
17
Aug 1, 2008 12:39 PM
