JustDSM Fp Green E85 Tune
Old Dec 1, 2007, 10:54 PM
SuPeRNeT's Avatar
Just got home after a long day.. Use to run an xede and had problems with it, Pulled it and JustDSM Ecuflashed it. And Let me tell you it is worlds better, driveabilty and cold start up issues are a thing of the pass.. Pulls better and is more consistent. Thanks again for a great tune!
Old Dec 1, 2007, 11:04 PM
MYEVOVIII's Avatar
Nice, was think on pump gas or race? I cant wait to get my cams and FP green. Seeing good results like this is great
Duh
Ignore me I did not see originally the E85 in the header
Old Dec 1, 2007, 11:07 PM
SuPeRNeT's Avatar
E85 that stuff is all over the springs. We have like 7 stations here.
Old Dec 1, 2007, 11:08 PM
whoang40's Avatar
I think he's using E85 from his sig. mods.
Old Dec 1, 2007, 11:20 PM
SuPeRNeT's Avatar
The TQ. Is great i was merging on the way home and it spun out the tires all the way through 2nd.. Crazy
Not sure what dyno it was but other evos with boltons were hitting 260-280's.
Old Dec 2, 2007, 12:11 AM
mplspilot's Avatar
E85 and green is a VERY good choice for an Evo!!! Good job!
Old Dec 2, 2007, 01:23 AM
recompile's Avatar
Looking good... BUT
1) That MBC is killing your top end. Your peak HP is at what... 5700RPM ? The green can hold ~25psi at redline and if you're spiking 26 then I'd guess you're tapering down to about 20 at redline, possibly less. Go back to stock boost solenoid and hold 25 as long as you can. A Forge WGA wouldn't be a bad idea either.
2) Why are you spooling so late? Peak torque at 4700RPM @ 26psi is not healthy for the Green... should be 1000RPM sooner. You could have a boost leak, exhaust leak, or maybe the dyno pull was just not started from a low enough RPM.
Old Dec 2, 2007, 06:29 AM
EVO8904's Avatar
Good #s for only 26psi, I wish I had E85 near me...
Old Dec 2, 2007, 06:46 AM
20Grockit's Avatar
nice numbers. im looking forward to gettin e85 here soon. keep it up
Old Dec 2, 2007, 07:18 AM
Mellon Racing's Avatar
hmm I'm getting ~400awhp on a green with 93 octane with a 26psi spike
are you running lower boost? I expect much more power out of E85.
p.s. I call bs on spinning through 2nd gear
Old Dec 2, 2007, 07:26 AM
SuPeRNeT's Avatar
It was a little wet out last night, and the onramp curves.
Old Dec 2, 2007, 07:28 AM
prostcj's Avatar
He shows 26psi in his sig. The shape of the curve looks right for an E85 green. Maybe that dyno reads low. The stock graph looks odd.
Old Dec 2, 2007, 07:29 AM
SuPeRNeT's Avatar
I have a ebc that i need to hook back up, it spools it way faster and holds it better too..
Old Dec 2, 2007, 07:30 AM
SuPeRNeT's Avatar
dyno reads low.. mellon your talking dynojet
Old Dec 2, 2007, 07:31 AM
yeah I hate dynos the trap speed and weight will tell the real story. either way I'm sure it's damn fast, congrats
Quick Reply: JustDSM Fp Green E85 Tune
